Geeee, hope your findings will avoid numerous cpu deaths, good job there.
Mike, another one dead???? Well, hopefully the 4600's still OK :p: Hey, BTW...you gotta PM comin ;)Quote:
Originally Posted by mikeguava
Originally Posted by s7e9h3n
Nope - playing it save with crap CPUs for now - lol
That 4600+ is sitting in a safe with five locks - an tossed the keys in the ocean so that I am ot tempted to play with it...
Lol
LOL so that's the key i found on the shores of our Australian beach :DQuote:
Quick Eva, send that key to me! Now if only I knew where in Miami Mike lived ;) .........Quote:
Originally Posted by eva2000
Got a new RDX200 here too, but I think its better stay in the box:(
I like my 55 claw 0519 "N' too much:) Its the last one..
Well I can kill CPUs now on demand!!! Pretty damn easy. ROFL. Just lost one...
I was very dissapointed when it became clear to me that DFI trouble investigation only went into "how dirty and abused" my CPUs were.
I had written them to look into specific things - but it became obvious that I had to do the work myself.
At the time during the investigation I was preoiccupied with far more serious troubles and didn't really take the time to be on DFI's balls, and my frustration with them only let me say things like " good job guys"
There is a mayor bug in the bios with the RDX - which is a certain cpu killer!
I just set a CPU to 1.25V + 104.8% on air on a brand new OPTY - and got 1.6-1.61V again. I'll have to look on where to upload the video - if anyone wants to donate another 939 - I could make a really fun video - something along the line of 1.0V + 133% -lol
The board which I had receive from DFI directly was supposedly tested for several days. It came with bios 10/11 - nothing had been changed or modded by me.
At first I had tried to take careful steps not to discredit DFI at all.
before the final result came back from DFI - I even made a silly post that I am already running another board which was a lie - - to reduce the already negative effect my post had created.
Me intitally posting really was intended as a warning - but now I am just pissed - because I feel that their "investigation" was solely a spin control on my back.
As far as the board goes - I will still use it - now I know how to avoid ( hopefully!!!) any further deaths - unless I decide to kill 100-200 X2 CPUs and send DFI the bill -just kidding
Guess it's time for Supreme Evil to look into things again
So 1.6-1.61V will kill an opty? Or, are you saying there other manual vcore combinations that you know of that are CPU killers? If so, what?
No - 1.6 won't kill an Opty - the Opty is still good.Quote:
Originally Posted by xenolith
It's not a specific combination of manually set Vcores ( this is what I had suspected at first - but now know better) it is ANY vcore plus the added % value after installing a new chip. This new boot of a new chip - the moment you set any manual value for Vcore will result no matter what 1.55V plus the added %. SO if you set something weird like 1.15 plus 113% - you'll end up pulling 1.7V - which on a X2 is a killer on air if you really put some load on the CPU
Thanks for letting us all know Mike.
DFI :nono:
1.7v kills? that seems a bit low?
Not on a low voltage X2 that runs fully loaded on AIR in 3DMarks where you're not monitoring the temps etc...both my 4600+ on 4800+ ( R.I.P.) do/did not like anything above 1.55V - even under extreme cold.Quote:
Originally Posted by STEvil
http://www.xtremesystems.org/forums/...ad.php?t=82185Quote:
1,75v :|
Well, I guess it depends on the type of X2 - the stepping etc. If you have the low voltage kind of X2 ( some run 1.23V default - others run 1.3xV default ) it changes quickly. There's some magic weeks and steppings of X2 that behave differently than what is described in that thread and can under no circumstance run at those voltages. Especailly under Miami air..Quote:
Originally Posted by biohead
Originally Posted by Dumo
Just read for the first time that you also lost a CPU on a RDX - care to share what happened in your case?
Heres Mike...http://www.xtremesystems.org/forums/...ighlight=dumosQuote:
This after RDX and FX55claw stopped @ middle of Superpi benching with 1.8Vcore and 3.6Vdimm and Zippy 700w psu. After that it gave 4 leds on for a second and off...everytime I powered it.
Then why not lower the startup value in the bios?Quote:
The way this happens I am pretty sure is when you switch CPUs - the bios gets stuck in the start-up value ( 1.55V) and adds whatever % you have added. X2 4800 RIP! I will have to confirm that later - to find a sure way to reproduce this problem.
Tmod
Originally Posted by Tmod
I haven't checked if the startup value will have any impact - but for some reason I have a feeling it would also not have any effect until the second reboot from manually setting it - just like the CPU VID CONTROL setting does not work until the 2nd reboot.
The best thing will be to avoid any VID SPECIAL CONTROL settings leave them at auto ( or 102.4%) and things should be safe. The worst would be 1.55V Vcore.
Completely missed that! Sorry bud!
Are you going to try disabling or changing the startup value and see what it does?Quote:
I see there are the following settings.
CPU VID Startup
CPU VID Control
CPU VID Special
Between those three there should be something that can be done to help with this problem.
Tmod
manually set the startup value to 1.35 for an X2, its meant to be raised for cold boot on uber-clocked chips, but it may be raising due to some weird non-detection issue.
Board is running 100% stable for 24 hours - overclocked and under load - with reboots all the time. As long as no CPU is swtich the board run really nice
^^^ Mike
Should I worry about my San Diego after posting with a Winchester (Never changed vcore or VID Special to my knowledge) Should I not boot it up, or just wait?
Originally Posted by JasonDTM
No need to wait - as long as you don't touch the Special control you're fine. Once evrything is settled you should be good for any changes if needed
BTW - Vcore in Smartguardian is 100% accurate for me - checked with digital Mutlimeter, and mem is just a tad bit low - same as perisvore's findings
I am not 100% cerain about this yet - but it's the moment that you change the VID Control manually after installing a different CPU - not just the first boot - but the first time you set the voltage manually. Haven't had time to verify this
Alright, is this a bios bug, or is it a componet bug? After monday I will not have another cpu, so it'd be SOL for awhile, The winchester I have is a little champ... has had 1.9v on air into and hasnt died just yet... lol
