The Asus is up and running.....starting from scratch so phase change is off, only running on air now....11x 250 1:1 @3-3-2-8 2.7v is a go so far, passed 3Dmark01se without a single hiccup, let's see what's up with 255 next.
update1: 255 @2.7v is a no go, car chase lockup once, dragon very unstable with shaky graphic, lobby lockup instantly!
update2: 255 @2.7v second try, only have 3 TREF options so I'd changed 3.9 to 15.6, car chase passed, dragon graphic is slightly shaky for couple frames but not too big of a deal as I can tweak that out later, lobby is smooth, nature completed no problem. test: PASSED!! ok....260 is next.
update3: 260 @2.7 benchmark failed to load, restarted it and car chase instant lockup on first frame. heh...I don't think I can get away with not touching any other values :p:
update4: 260 @2.7v changed TRC to 8, TRFC to 18, RW bypass to 8, bypass max to 7, idle cycle limit to 256. Read preamble to 6, async latency to 9. benchmark loaded...but car chase is borking pretty bad, I think the ram need more juice.....bump it up to 2.8v that is.
update5: 260 @2.8V, neither lose nor tight timing work, all 3 TREF attempts failure. Since this ram is officially rated by Mushkin up to 2.9v, I'll give it one last try.
final update: 260 = FAILED!
