Heres a quick one.....
http://img42.imageshack.us/img42/523...shot0340xl.jpg
No its not. s939 Opteron 1xx are based on the San Diego core.Quote:
Originally Posted by ozzimark
The Semprons have this value set to a static 69C, all chips will have the same values! Only A64 (FX, X2) and Opteron chips have variable MaxTCase/VCore.Quote:
Originally Posted by GMX
CPU-z is wrong. 20F32 CPUID stands for a Toledo, you have a "crippled" Toledo CPU, which in most cases overclocks better than the real Manchesters.Quote:
Originally Posted by Fr4nk
As I already stated in this thread, A64s (FX, X2 included) have variable vcore and variable MaxTCase values.Quote:
Originally Posted by alpha0ne
From the so far limited results we have, the higher the MaxTCase, the higher the chips will OC on average, you have one of the highest MaxTCase temp I've seen so far. Judging by the really high MaxTCase and the low stock VCore (1.3v and not the more common 1.35v) if my theory is correct, your chip is supposed to be a gem, or at least nor far from that.Quote:
Originally Posted by don_vercetti
The theory is explained in the first post.Quote:
Originally Posted by mongoled
As a rule of thumb, the higher the MaxTCase rating on a chip is, and the lower the stock voltage, the higher are the chances of getting a better OC out of the CPU.
Hey The Coolest, I was wondering how come my max case temp is 61c and my chip oc's like crazy? Mine is an early 3800 manchester (see sig). I thought the higher the max case temp the better oc you will get. Now my voltage is 1.3v so maybe thats why,,, dont know.
All CPUs are unique, its just in *GENERAL* processors with higher rating, and lower stock voltage overclock better than processors with lower ratings. In addition 61C and up is a very good MaxTCase rating.
Ok cool,, I was just wondering. I do like the proggy though! :toast:Quote:
Originally Posted by The Coolest
:slobber: :slobber: :slobber:Quote:
Originally Posted by Dumo
That's almost as unique as this one ;) :
Rev E6 A64 4000+
http://img12.imageshack.us/img12/4749/maxtcase4md.jpg
Week 0515, CABGE. 3700+ San DiegoCode:CPU Information (CPU #1):
Standard CPUID: Family: F, Model: 7, Stepping: 1
Extended CPUID: Family: F, Model: 27, Stepping: 1
CPUID String: 20F71
Processor APIC: 0
Processor: AMD Athlon 64 3700+ (San Diego)
CPU Speed: 2871.27 (261.02 x 11.0)
Revision: SH8-E4
Platform: Socket 939
Startup VCore: 1.400v
Maximum Case Temperature = 59C
2800mhz = 1.396V CPU-Z
2850mhz = 1.404V CPU-Z
2900mhz = 1.501V CPU-Z (Im not quite sure on this one, but Im trying for 3ghz so I will get there!)
Concorde
Here is the 3200 I just got its already done 3.5ghz 1m stable--
Standard CPUID: Family: F, Model: F, Stepping: 0
Extended CPUID: Family: F, Model: 2F, Stepping: 0
CPUID String: 20FF0
Processor APIC: 0
Processor: AMD Athlon 64 3200+ (Venice)
CPU Speed: 3000.76 (300.08 x 10.0)
Revision: DH8-E3
Maximum Case Temperature = 65C
Written by: Arthur Liberman.
Contact me at: Arthur_Liberman@hotmail.com
Figures, it has a 65C MaxTCase rating ;)Quote:
Originally Posted by njkid32
Hey nj very nice OC thereQuote:
What week is that CPU, I notice its an E3
Thans! Its a 0521DPMWQuote:
i'm a newb to forums please bare with me i just orderd 2x1gig crucial ballistics ddr500 for my asus a8nsli prem w/4800x2. Do i need to overclock the cpu to 250 w12x multiplier. Or can i just set the ram to 500 in bio without overclocking. old ram was corsair xms 2-2-2-5 but had to back it down to 1t to get a desent overclock. but still had fast timming. know if i run the ddr500 at 2t will i be able to overclock to the same speeds as the ddr400 while at 1t. if i did not explain my problem correctly or in the wrong thread please let me know
asus a8n-sli prem
corsair xms pc3200 ddr400 cl 2-2-2-5 (old)
2gig crucial balistic (new) pc4000
xfx 7800gtx oc
coolmax 600 psu
audigy 2 zs
eerrrr
wrong thread
I've had two X2 3800+ chips. One had a MaxTCase temp of 61, the other 65. Both were rev. JH9-E6 and had a stock vcore of 1.35. The one rated at 61 would only get to 2.5Ghz and needed a ton of vcore (1.6) to do it. The one rated at 65 will get to 2.6Ghz stable and only needed a vcore of 1.47.
Guess which one I kept. :)
Standard CPUID: Family: F, Model: 3, Stepping: 2
Extended CPUID: Family: F, Model: 23, Stepping: 2
CPUID String: 20F32
Processor APIC: 0
Processor: AMD Athlon 64 X2 4800+ (Toledo)
CPU Speed: 2595.40 (216.28 x 12.0)
Revision: JH9-E6
Startup VCore: 1.350v
I do have to say that my CPU has been over like 80c degrees ( when my watercooling failed) and remainded stable till atleast 75C so, guess I'm pretty lucky :) But then again that is with the crappy abit temperature sensor thing ... It can't be right .... I know that ..
not my max oc infact it was the first oc i did out of the box as you can see not to bad uh and look at that nice high t-case :)
peace perc,
CPUID String: 20FF0
Processor APIC: 0
Processor: AMD Athlon 64 3800+ (Venice)
CPU Speed: 2903.36 (241.95 x 12.0)
Revision: DH8-E3
Idea by: Petr Koc.
More info at: http://www.thecoolest.zerobrains.com...topic.php?t=83
Download the updated version, it will now recognize the s939 Opterons. Same linkQuote:
Originally Posted by Perc
my Opteron 144 CABYE 0536 GPMW
http://www.fileshosts.com/DFI/NF4_SL...x/cpuz_cbi.jpg
http://www.fileshosts.com/DFI/NF4_SL...cpuz_cbi_3.jpg
Originally Posted by eva2000
Did ya overclocked ya CPU? How much MHz and Vcore did ya get?
Here's my contribution, 3200+ venice
long time lurker.
CPUID String: 20FF0
Processor APIC: 0
CPU Speed: 2574.75 (286.08 x 9.0)
Revision: DH8-E3
Maximum Case Temperature = 55C
Idea by: Petr Koc.
i can do 2.6..but not fully stable..figures from the max temp though....definitely some kind of correlation.
my 2nd Opteron 144 CABYE 0536 GPMW http://i4memory.com/showthread.php?p=23158#post23158
it's maxTcase is 2C higher than other one at 59C and clocks higher with 0.05v less vcore than my first Opteron 144 CABYE 0536 GPMW :)
http://www.fileshosts.com/DFI/NF4_SL...rpi-1m_tn2.jpg
Standard CPUID: Family: F, Model: B, Stepping: 1
Extended CPUID: Family: F, Model: 2B, Stepping: 1
CPUID String: 20FB1
Processor APIC: 0
Processor: AMD Athlon 64 X2 3800+ (Manchester)
CPU Speed: 2661.00 (266.10 x 10.0)
Revision: BH9-E4
Maximum Case Temperature = 61C
Idea by: Petr Koc.
It seems most X2s show Tcase > 60
I think what really matters is what they show for startup Vcore ;)
CPUID String: 20FB1
Processor APIC: 0
CPU Speed: 2860.12 (286.01 x 10.0)
Revision: BH9-E4
Startup VCore: 1.300v
Idea by: Petr Koc.
