well this is the reason why most people start with single stage systems, your in over your head now. If you want help, give a complete list of pressures en temps.
btw when your low stage compressors aren't running their isn't much load applied to the high stage. So 2nd idea is useless. although I already warned you when you started on your project that the high stage might be to small @ teampuss. You want to call danfoss about it? WHY? they have all their compressor specs online.
Try adjusting the superheat screws on your TXV's for starters.
