Originally Posted by LarsK
Yeah It's me allright. I agree system should be 24/7 stable, otherwise it's not really useable. At 345 Mhz it actuallt is completely stable without any speed variation on the cpu either.
I actually run my OS on a 2x WD Raptor SATA Raid 0 array, also a couple of Raptors on the SIL SATA controller, an old Maxtor ATA drive and 2 dvd-rw's, so both ATA controllers are in use as well. I've got all like 5 USB 2.0 devices plugged in the mobo as well, 2 of them drawing power from the mobo, both network adapters are being used and I use the on-board sound card as well.
I've got all motherboard voltages maxxed out, 4x Corsair PC5400UL blocks mounted @ 2.3V so considering that everything on the mainboard is used 24/7, I think acheiving a 24/7 stable 345 Mhz fsb speed is pretty darn good for stock cooling too. I'm going to put water cooling on it here pretty soon, as well as volt mod it a bit, at least NB/mem term. and Vddr. I'm hoping to get 360-365 Mhz 24/7 stable without any cpu speed variation.
