http://img82.echo.cx/img82/306/2900pi32m7gr.th.jpg
Dfi nf4 ultra d
xp90c + 80mm
Dfi nf4 ultra d
xp90c + 80mm
wc over?Quote:
Originally Posted by overcrash86
Originally Posted by eviLRuLeZ
yes, WC home made :banana:
now i get 27s to superPI :D
Ram walls at 270MHz regardless of voltage (2.75-3.15) which is a major letdown as I let
go of my BH-5 to get this supposedly sick TCCD. Might RMA if newer TCCD is worth it?
The processor also seems to wall at just over 2.7GHz regardless of voltage (1.45-1.75) or memory divider.
This DFI has been treating my TCCD rather brutally though, I know this ram can run 310MHz
CAS 2.5-4-3-7 1T because it handled that 1:1 on my old chaintech VNF4 ultra @ 7x310MHz,
but I cannot for the life of me, regardless of how loose the timings, pass 270MHz with stability.
I might just pop this 3000+ in the Chaintech when it's back from RMA just to see...
Maybe it's the venice that doesn't like your TCCD? Was the reported loss of bandwidth vs winchesters only in TCCD and not UTT or was it both?
3000+ LBBLE 0515FPMW
vCore: 1.50V in BIOS, it SAYS 1.456V in CPU-Z
Cooling: AIR - Zalman 7000A-AlCu
Purchased at: Filtech Computers in Toronto.
RAM: OCZ 2x512 3500EB 2.5-3-2-6-1T 2.80V
http://individual.utoronto.ca/bzhou/2700-300x9.JPG
It's still running Prime95. I wonder what it'll do on water!
Where did you guys get your CPUS? Was looking for a 3000... Trying to decide which place is good
Now by week and stepping.... oh and this AIR cooling only...
http://people.ucsc.edu/~wyattp/week.JPG
http://people.ucsc.edu/~wyattp/step.JPG
overcrach86:
300*9 at 1.4v stock cooling ?
300*9 at 1.375v wc ?
so you think that better cooling gets less voltage needed for same setting ?
Actually it turned out to be the BIOS, 310P is much much better than any of the 510's.Quote:
Originally Posted by TheMeatFrog
I'm running stable 9x300 right now, finally. :toast:
Hi all, new to this forum :)
Im going to be getting a 3000Venice -LBBLE 0517 APQW on wednesday. Im using a Asus A8N SLI motherboard, most of you all seem to have DFi's is there actually anyone on here that uses a asus a8n sli for overclocking using the venice?
Thanks all,
Cool_dude
Are you Gangstar from CPUCity forums? :)Quote:
Originally Posted by cool_dude
just superPIQuote:
Originally Posted by TEDY
1.328 stock cooling ,I did not test with my WC
i think 1.312v it work :D
Originally Posted by [timko]
Yes i am :D :woot: also are you a member of ocuk? Im sure ive seen you about on their forums...
edit:
....yes you are :cool: :D
Cool_Dude, yep I posted about the APQWs for you at CPUCity :)
Anyway, here's one user with the same CPU you will be getting...
http://www.xtremesystems.org/forums/...&postcount=202
...however, they've not stated what mobo they have yet :)
wow - 2.8ghz at 1.45vcore, impressive :)
Cant wait for my venice! :D
If he also is using a dfi, will i be the first on XS to overclock a Lbble 0517 on a asus a8n sli? Saying that i havent seen no overclocks using an asus a8n sli.
http://wowgame.free.fr/3000+%20939/l...mw/2808spi.jpg
Box cooled :D
erm i think we all have to decide which V are we gonna use/mention...the one in bios or the one which is reported in windows......
damn it overcrash :)
watercooling really helps :)
here's mine with 7000B-ALCU
http://img212.echo.cx/img212/5230/su...b3201zk.th.jpg
Venice 3000+ 0517EPMW
COOLER EXPRESS -21℃.
1.488v 3.2GHz /150 with BH-5 256MBx2 1.5-2-2-0 3.6v pi 1m :)
not bad~ :D
Antec TrueControl 550W 20pin...Quote:
Really good, how about cooling?? Do you have any pics??Quote:
Originally Posted by qk4722
Have you tried with more vcore?? Results?
qk4722 : ok now i don't believe you anymore....one time you say DPMW another EPMW...
and 350*9 on only 1.525v ? yeah right........
