Originally Posted by Mussels
That is correct...2t is what people normally run with more than 2 stick to get it stable it cuts down on performance...when it is at 2T 1T is the best and increases performance
Dragon
Dragon
anyone of you know what the best bios is for a venice + bh5 ram?
try the 310P and on, it varies system to system.
(310P, 316. and 510-2 are the ones that work best here)
Venice / UTT
3.10p and 3.16 also i have heard that the 5.10-2 work VERY well with Venice and BH-5/UTT
Dragon
BH-5 what, 512mb or 256mb, SS or DS rams?
Or is't any different :confused:
DFI nF4
Venice 3200+
2*256mb SS KHX3000 BH-5, +270FSB
2*256mb SS KHX3200 BH-5, +270FSB
2*256mb DS KHX3500 DW50, +270FSB
ther's my test rams
( SS= singlesided, DS= doublesided)
Can someone clarify this for me?
Some people are saying that xxx-1 bioses are better for TCCD RAM, but others are saying it's xxx-3 which is the more suitable? I know that it says that xxx-3 are the optimized ones in the first post, but I'm sure that I read someplace else that this was the wrong way round?
i beleive -1 is a general bios for all ram, -2 is for UTT (Vx) and -3 is for TCCD.
-1 or -3 work fine with TCCD, some people have better luck with different ones.
oh, and for a while here either the info or the links was backwards for some of them, read back a few pages i beleive it said it somewhere.
What about the Hellfire BIOS? I'm just running it and it seems to be fine with my BH5 :banana:
Link to DFI Forum/ Hellfire Thread
w00t!!! boys and girls HellFire is back in the game this is a crazy moment he was the one that made some of the most legendary bios for the NF2 boards and now he is making them for the DFI NF4 w00t!!!
Dragon
Pershoot have you updated the bios cd?
Dragon
It is all fixed and yes you are right about what ones work for what it also says at the bottom of the bios...maybe I should put it at the top also...
Dragon
Dude.... you're running a beta bios. get the hell over it.Quote:
Originally Posted by muzz
go back to 310P and you wont have it, these bioses are not meant to be stable or officially supported.
yes on 5/20.Quote:
Originally Posted by FireDragon
edit: http://www.xtremesystems.org/forums/...&postcount=192
Dear mates,
Did anyone try both BIOS 5-10.1 and 5.10.3 for TCCD chip? Which do you feel better? As it is stated here
Will TCCD be really better in orange slots with BIOS 5-10.3?Quote:
- 5.10-1 Updated 5.09. 1 uses 3.26 ram table (TCCD)
- 5.10-3 Updated 5.09. 3 uses 3.10 ram table (TCCD,BH-5,UTT) TCC* will run better in orange slots.
I beleave it is so as UTT is better in yellow for most bios...and I have heard that TCCD is better in orange...at least witht he 5.10-3 that is...With UTT some people can gain 15MHz by going from orange to yellow...
Dragon
They might not be offically supported but they DO work MUCH better in almost all cases then the offical none modded bios...you trade speed and performance for slightly decreased peace of mind from having a beta bios...Quote:
BTW people have had the proble with EVERY bios under the sun NOT JUST beta and modded bios....
Dragon
Originally Posted by pershoot
Ok, thxs man just want to keep this up to date...
Dragon
ok firedragon, i had not heard anything about people having this on normal bioses. i work as a reviewer with OCZ and got the info from those guys, and word was that it happened very rarely and only with beta bioses.
and UTT works better in yellow?? :stick: damn i gotta try me that :D
They know there stuff yes but they also only know from what they have treid not what has happend to others...I love OCZ wish I was a reviewer...
Dragon
i haved the 6.00 pd 25-1-2005, and have some problems booting from diferent hard drives, have to disable external cache and in some cases cpu internal cache.
for what is external cache?
any guide for the rest of values of the bios not dram either cpu ?
i`m going for 3.10,didnt see 3.10 p support by dfi
regards
I have a question how to flash the bios without a floppy drive:
Can I boot from a USB stick with the DFI Board or have I to flash from CD? USB stick would be nice because that was the reason why I bought me one.
Im just get DFI DAGF few days ago,
my question is ,
can all those BIOS listed in the first page can use on my board ?
If cannot, then which one would you recommend ?
currently i was using official lastest BIOS...
No, DAGF has different BIOS.
Hey just use winflash...that is what I use just make sure EVERYTHING is set to stock before you flash and it should be all good...
Dragon
Winflash has a "Reset CMOS" option that you can check.Quote:
