One of my SP PC3200 AA4T just died too.. So now I have exactly the same problem as you Sobol! :(Quote:
Ive had twinmos sp aa4t and 1a4t die on me and the aa4t isnt gonna be easy to get replaced, I called twin tech support and they said maybe it can be repaired but itll take 6-8 weeks to get back, because has to be sent to cali then they send it to taiwan or something crazy like that..
sucks :(
Just talked to the company I bought the ram at, and they say that they have gone bankrupt! So now I have to send it to Twinmos instead :stick:Quote:
Originally Posted by S!1v3rB@cK_Dk
That sucks.Quote:
Where did you buy them?
Im really regretting not putting 4 sticks aside for backup. They were so cheap...UGH.
I do have a local dealer with Twinmos 1A4T sticks, mid $50's each, I think I may take my machine in to "test" a couple sticks for compatibility :D and buy a pr for backup.
They never had AA4T though, so sad.
why those twinmosses dye allthe time? i have atm aa4t 2x512 they are looking nice 250mhz 2-2-2-5 @3,3v . cant undetstand why they just die?
No biggie, just SOME of them die. But if they live they live for a long time. It's just some fail, and for safety having set aside some backups would have been a wise decision....especially when they were $54 a stick at TheEgg :fact: :nono: :clap:
www.cheeep.de but I just talked to twinmos in Holland yersterday, and they would be happy to replace the dead stick.. So atm my stick is on its last journey which goes to the Dutch fields of dead ram, also knows as the Twinmos Department in Holland :fact:Quote:
Originally Posted by Monge
Glad to hear and good to know who to contact :)Quote:
I have some Twinmos UTT/CH-5 myself and I hope they do not die.
Any idea which chips -1A4B are? (On TwinMOS Twister BH5)
Winbond "new" BH5 like the name says...
Hi there,
Just got my 2x512 TWSP PC3500 frm RMA.
both stated BH5 before i send it to RMA,but now the faulty stick replaced to ACMT 0536M TMD7608F8E44F any idea which chip is this?Hynix D43??:mad:
Will there be any problem if i mix clock both chip(1x BH5 and 1x non BH5):slap: :slap:
whats the info on the label?
check first page if it matches or not....
Nothing match,i couldn't find ACMT:(
here's the code from label:
P/N:M2GEJ16A8APPFF081ACMT
cHIP:
0536M
TMD7608F8E44F
Hi guys, just got hold of these, can someone confirm for me wht these are, if i have understood correctly these are UTT BH-5's?
http://img111.imageshack.us/img111/2...pbh50we.th.gif
http://img124.imageshack.us/img124/3...pbh5mod2cn.gif
Cheers
1A4T -> bh5 ^^Quote:
Originally Posted by mongoled
Sorry, are you saying these are the original BH-5's??????Quote:
Originally Posted by $ilver
:slobber:
Alonso @ 1a4t + aa4t = bh5 & utt , just desapear from stores quickly and all the stick that come [here in Greece] are non-utt-bh5 [uccc , and other ''values'' ] .Also the speed premium are not bh-utt any more.
Have u you know something about this . ? Twinmo's stores are out from winbond chips ?
egamota, ti einai auta ta ram? UTT or BH-5? :)Quote:
Originally Posted by Athens[2004]
Mongoled,
Your sticks are BH-UTT.
Hey thanks for verifying tht for meQuote:
Originally Posted by largon
Ξάδερφε mongoled @ all sticks with batch 1a4t are ''new'' bh5 and with aa4t are UTT ,
bh's also can do ''trfc'' = 12 , instead of UTT's that with trfc = 12 are freeze or dont boot.
By the way put that damm sticks on your dfi and tell us what is :hehe:
ela filoudi :)Quote:
Can u post me a A64 tweaker pic, of wht settings I should try for with this ram, i will try it out tomorrow (am in middle of prime95 testing)
Yes, AA4T are the UTT based on new run of the CH5 chips.
While 1A4T are the UTT based on new runs of the BH5 chips.
Rumor had it the new run of CH5 had some improvments over the original CH5, while the new BH5 was just another run of the same "good stuff" BH5 chips.
If they dont BREAK on you, the AA4T UTT (CH5) are without question THE BEST there has ever been. 4x 512M 3.1Volts 255Mhz 8,2,2,2.0 for me in DFI NF4 SLI-DR.... and that is WITH the FK'd up Vtt issue. But the UTT (CH5) have had some premature death issues, I have 8 sticks here, and 5 are perfect, 3 have "issues" where they freak out with voltage over 3.1V now.
I cant begin to understand why they didnt CRANK out a ton of the new CH5. The best ram ever made. It will require DDR2-1000 to TIE, not beat but TIE this ram in actual use.
AM2 chip and switch to DDR2 is utter folly. Oh wow, AM2 will support the equivalent of PC3200 (DDR400) "STOCK"!!! Imagine that, a true breakthrough, wow, yippee.
