so I should use the timings that U posted in thread about 6200?Quote:
Could anyone please post these timings here or give a direct link to the post that has them?
Thanks in advance.
Yes,the timmings are:Quote:
Originally Posted by nodak
TIMING0 : 060b1003
TIMING1 : 05010407
TIMING2 : 00240306
After flashing,do a clean driver and RivaTuner install,then check in RivaTuner
in NVIDIA graphics processor registers to make sure you have these timmings
Thanks a lot. Will post my feedback tomorrow.
You have Palit? Would you like to try a modded bios for 1.5V?Quote:
Originally Posted by uKER
No luck, guys. Modded the BIOS but RivaTuner reported no change in the original values. :(
Did you modded using NiBiTor 20.a?Quote:
Which is your card timmings?
trans_am please more pics of gfx and mods and etc :)
can anyone tell me what should i do with my BIOS ?
freeweb.siol.net/tadej27/BIOSBACK.ROM
Can someone give me a detailed explanation on how to do the pencil-trick on my Inno3D 6600 AGP 128Mb card ?
My card looks like this (except it doesn't have the memory chips on only one side, it has on both sides):
http://www.3dvelocity.com/reviews/in...s/image010.jpg
http://www.3dvelocity.com/reviews/in...s/image012.jpg
i have got this card " WINFAST PX6600 TD 128mb PCI Express "
is there any modded bios with higher gpu voltage then stock ?
is there any soft to change gpu voltage?
Did anybody make memory voltmod on Asus 6600 AGP???
I changed timings, but it's no result...
PLZ help russian modders... :)
Hello all.
Seaman, Jacker, I discovered that the "relaxed" timings for memory works on 128MB cards as well as 256MB cards, whatever the card manufacturer (there can be exceptions though) .
The only thing you should consider when editing the timings with NiBitor is the TimingSet you are editing. If you want to be sure which is the right TimingSet (from 0 to 7) for your specific card first load your card's bios into Nibitor, then use RivaTuner and go to Hardware reports -> VGA Bios Information and then compare the 3 parameters named NV_PFB_TIMING0, 1, 2 with the ones in Nibitor's TimingSets. When you matched the whole 3 with a Timingset of 3.... edit them with the relaxed timings found up in this thread !!
My Sparkle 6600 256MB AGP works now at 600 / 665 ! (crappy 4 ns memory).
yes..exactly...this card is blocked i think. Sparkleultra bios I cant load to it, no vmod i have found till now, I changed timings as well and no result of course. Any help?Quote:
Originally Posted by JacKER
Read up what I've said about TimingSet , did you do as I suggested ?
yes, but still the same....Quote:
Originally Posted by sabinus
Does enyone know how to Vmod this card?
ASUS 6600 non GT AGP A4 core
http://www.tweak.pl/images/asusgf6600agp.jpg
:( :rolleyes: :confused:
Hi guys...before doing any vmod on my sparkle 6600 agp I want to buy a nice cooler such as the zalman vf700-cu. The problem is that I can't find anyone who has tried to fit it into a sparkle 6600 agp...i notice that the sparkle pcb is not the same of the nvidia reference board so I don't know is the mounting hole are the same!
This is the nvidia reference:
http://www.xtremesystems.org/forums/...id=35600&stc=1
My sparkle:
http://www.xtremesystems.org/forums/...id=35602&stc=1
As you can see the clip of the heatsink are not in the same place!
If someone as some info's please reply this topic!
Tnks for ;)
can sombody help me?
Yesterday I´ve flashed my Sparkle 6200 PCIe 128MB card.card works butt drivers can find in windows any nvidia card. I found that is because my card has 0149 ID that coresspondent with 6200 but 0141 are the cards from 6600 series.I need to change the card ID from 0149 to 0141.Enyone know how to do it?
Hi! Can someone explain, please, how to make pencil vmod of asus en6600 128mb (pci-e)? Or post a link, where I can read about it. I've searched this thread, but couldn't find information about pencil vmod of pci-e card, found only about agp...
I've Manli GF6600 PCIe with exactly same pcb.Quote:
Originally Posted by PuZo
I need gpu mod for it. No matter if it is pencil or resistor.
Btw, my DDR1 sucks, 2.8v only does 645mhz :(
The core is @ 551mhz for 24/7 :)
Guys from where to get this SParkle ultra Bios
i have a PCI-e LEadtek 6600noGT and i would like to try this bios on it but no Voltmods
raises one question- I hawe a ASUS 6600 EN silencer (256MB) u can see some cind of picture here: http://tienda.baluma.com/images/prod...0_silencer.jpg and the question- who knows how to make a woltmod to that kind of card??? (i mean a tested way, i dont wan to screw it up) right now its on 422Mhz gpu and 588Mhz of ddr and that is not much and i would like to give a little more fire.... so ideas anyone?
