Xtreme Watch Dog is designed to run as a service and gives you a bit more control, if you want it via a settings file. So it depends if you want something that runs as a service out of the way or not really.
Xtreme WatchDog is what all the cool kids use! :cool:
if that is true i'm sure i must allready have it somewhere :D Seriously with the help i have been getting i don't think i will be ofline very long at all. I need to ask help in in harddrive area to straighten out my drive image problem, and i'll be all set.
edit: just checked my stats, this 3.4 is doing some major crunching, glad to put it to work doing some good.
hmm ok i installed 2 nodes useing the installer. after it installed everthing was fine and i could see the 2 d2ol icons in my taskbar. when i restarted my pc they are now gone. how do i open the GUI? [/n00b]
It might show up if you go to start and then find D2OL and run it from there. Or just find the .exe in the home directory
jjcom
I have an old node (accidentally loaded D2OL twice, so one of the nodes isnt being used). When I load D2OL on another machine, would I delete that current node.prp and load mine, or do I have to do something differently.
If the not in use node has NOT been regitured, then yes do that. if it has, install D2OL on the other computer and copy over the node.prp file
jjcom
yea, the node was registered. I thought I did it wrong, so I reloaded it, and found out I had already done it correctly. So, all I do is load D2OL and then copy over the node.prp. Thanks for your help.
yep, basicly, just replace the node.prp file that is made when D2OL installs and use the "old" one
jjcom
http://tn-d2ol-stats.homeip.net/team...=XtremeSystems my stats show up on this, but i don't think it put me down as a new member.Is this because i used installer on D2OL home page (not ezinstaller). Will this not show my milestone things such as passed 500 etc.No problem as i'm on the team just curious.
It has you down as a new member... (You are only in the new member list for a week) And yes it will track all of your stats & milestones just like anyone else’s.Quote:
Originally Posted by heater918
what's up with team Norway anyway? i'm swedish, so i'd love to see us beat them bad. soon.
also i've started "folding" (what do you call D2OL-ing??) today, for your cause. My node is my father's A64 workstation hehe... gonna add my own computer (and new rig) when I get them.
D2OL-ing is Crunching! :up:Quote:
Originally Posted by krille
And welcome to the team!!!!! We will be taking team norway down very soon.
Excellent ... let the crunching begin! :D
how do i check if i have any candidates saved up on my hard drive? and how do i add them to be uploaded?
As long as you are on the internet your clients will auto upload every 6 hrs. They won't them unless you have your Agents set to run offline.Quote:
Originally Posted by faruquehabib
Every time you restart D2OL it will upload any completed candidate packets that were left on your HD when you shut it down. You can see how many results a running D2OL client has by opening the java agent or right-click on the tray icon, choose "Status...", then click "Manual Udate".Quote:
D2OL isn't buggy like DF was by losing track of results.
Not true... Your resultQueue.dat can get corrupt and you won't be able to upload... or your queue can just totally disappear! :eek:Quote:
Originally Posted by Paladin
Heh, never ever happened to me on this project. On DF it seemed like I had to manually fix the upload list at least once a week on every machine. Ergo D2OL "not like DF". ;) (Semantics.) :stick:Quote:
Originally Posted by Rodzilla
True! ;) you got me there!Quote:
I am new member. I am also new to folding and what it does. I have 4 systems at home and one that is on 24/7 as a weather station that uploads data every 15 minutes and thats it. So i'm thinking that system would be a good canidate. However not sure what this d2ol does and folding is all about and if there is a security issue? Thanks for any info. Ohya does a fast or powerful system really help? dual Ops 4 gb ram RAID0 and over 900G HDD space? is this overkill?... Just a thought as I have the parts..
Sorry for the PM Jeff....
D2OL uses your cpu's extra cpu clocks to help find cures for diseases. It is usually set to the lowest priority so that it doesnt interfere with other cpu intensive programs. It uploads every 6 hours. Nothing is overkill for D2OL. There is not such thing. Raw megahertz looks to be the best. DTW, I dont think we have mny people here with opterons.Quote:
Originally Posted by FROG
To add to what mod said... There are no known security risk for running D2OL... it uses port 80 so there are no special ports open to run D2OL.Quote:
yea, forgot that point, thanks.Quote:
Thanks .. So port 80??? So if I am ethered in a network it will work using that line?? or Do I need to config something?
