Bla$nA
I think he's running Mushkin BH-5s with insane volts.
Bla$nA
I got a new k0411 and with the chipnumber 0443 korea and its not working at all no post :-(
Do you mean everything spins , like the fans and etc...but the monitor remains on idle?Quote:
Originally Posted by Stinger
yes everything sounds normal but it wont turn on the monitor
A few things, is the agp seated completely? I've fallen for this a few times.Quote:
Reset CMOS?
Yes I'v have reseated it 2-3 times. and every piece are tested in my barebone (Cpu,mem, x800xt) and works Can it be the psu that dont have the power? Topower 520w
I had a similar problem so had to rma both the board and cpu, got a new cpu and Neo2 and now theres not problems so far. It might be the cpu, the funny thing for me is that i could boot/post just using dimm3 (single channel).Quote:
Is you ATX 20pin cable pluged in correctly?
yes its plugged in correctly
Do you have another cpu to test with?Quote:
As the board is brand new, the board should be fine, were you using the cpu before?
I just went through something very similar on Mon/Tuesday of this week. Turns out my 4 pin 12V power connector was in, but not all the way, til it clicked. Once i did that, no problem.Quote:
I heard the klick but I'll make shure its properly seated
Got my new board here is this morning, it's a
K0411xxxxxx :D
with a
0442A2 Korea chip :toast:
Which is the better chip, Taiwan or Korea - or are they both as good as each other?...
Cinders.
Nice, should clock well for you as my 0440A2 Taiwan is doing really well.Quote:
Originally Posted by cinders
Doesnt really matter Korea or Taiwan as long as the stepping is after 0438A2
Excellent! Only 4 hours until end of work and the weekend lies ahead...Quote:
Originally Posted by [ r2 ]
:D
Does anybody have had a neo2 with this chip,
039465.4 0403A2
Taiwan
Mine has this one and just wondering if it is any good or not and how far other ppl have gone with that.
Looks like anchient chip to me... week 3 ?! :p:
Thats must be one of the early chips produced. Are you having any troubles running your system?Quote:
Originally Posted by Byron
Nope,no probs at all, just same issues with prime95 while overclocking (runs ok at stock) but it can do 272x9 fine... or 286x8.5. My cpu is not good, tops at 2.46G (246x10) anything more than that and prime95 will fail. Other than that is stable and good system overall. In terms of overclocking must be the cpu on-die mem controller as usual.
Using PQI mems with TCCD chips, had ballistix using Micron chips but it was not overclocking as good as with the PQI's :) (wouldn't do more than 245fsb's no matter what multiplier etc.)
Are you able to complete Super_pi 32Mb pass at 278HTT 1:1?Quote:
Nope, my cpu controller tops at 272x9. At 274 i'm getting few errors when i run memtest86 (test5), the settings i state for the clocks on my post above they are with 1T, 1:1
I can run 32mb SuperPi at 272x9.
Hell, don't know what is going on here... yesterday it was running fine prime95 at 272x9, i tried today to run prime and it stoped after 50mins... then when i tried to restart it, it failed within 10 mins... neither could run superPi 32mb's... WTF?!
Think i've had enough with all that 64bit s**hit i'm going back to 32bit enough is enough.
just looked and it seems i have a 0409A2 orwoteva they r called.... gah i want my chip!!!
probably asked 1milllion billion times but is this a good chip (09A2) will i get 270HTT? :D or is there loads of problems..
Dynno what the hell is going on guys, i've dropped the AGP voltage down to 1.5 (was 1.65 before) and set the mem to 2.65 (was 2.6 before) and now it is priming... please somebody take me to the nuthouse!!! :D
your psu is probably not powerful enuff, lowering the AGP has allowed more volts (stable) to ur Vdimm (memory) and just made the whole thing stable.
My psu is a Enermax 475W Noisetaker, measured on the rails:
3.3v -> 3.38v
5.0v -> 5.12v
12.0v -> 12.18v
I've measured them with a digital multimeter... don't you think they are fine at full load? ;)
Edit1: might be some kind of mobo voltage drop though.
Edit2: prime just failed after 1 hour...
finally i'm soon able to start with my every year hardware update of case-x-treme (yeah kinda w00t name i know :banana4: )
my msi is an k0411 0440cd
not tested yet...1 GB Kingston KHX 3200 BH5 and OCZ Booster laying around here...i really need a processor...hope a 3000+ winchester will work under the -today buyed- prometeia mach I @ r507...
really looking forward for pics and results...but as i told you before...i need a processor first :(
