Originally Posted by mytekcontrols
404Power, Thanks for the heads up on the question (now I get it :rolleyes: ).
Just curious, but what kind of temperatures and watt capacity are you after? I noticed that your system is a 2 cascade system, which is quite capable of very low temperature operation (assuming the load is small). So for instance, I'm guessing hypothetically that a 1hp 2 cascade system with Sub-Cooler, should be able to do -150C at around 30-50 watts. However as the wattage increases, a third cascade would probably be needed to maintain such temperatures.
