Thx for that info AndyOCZ , i have that board soon
Luckely the vmods on that board are very simple
so what's the deal with OCZ Booster nad MSI Neo2 Platinum NF3 mainboard?
maximum 3.4v - that what is says on the CZ website. but i see people giving even 3.8v... do they boot @ 3.4v and then adjust to > 3.4v once they are in Windows???
Mine is doing 3.6v. As for Adjusting the Booster Voltage, I'll go into Bios, use a multimeter and read the Vdimm mosfet's voltage. then I'll adjust it to 3.6v. Reboot and that's it. Everytime when i on the system it will boot at 3.6v.Quote:
Originally Posted by bachus_anonym
Hello, I have posted B4 that the 3.4v is only the speed TESTED. Not maxiamum. The guys doing the tseting were told to do 3.4v and call it good. the boards that show higher were tested my some of out trusted friends or my one of us at OCZ that has the nerve to go for it . ;)Quote:
As the tiltle says, the booster work just fine with the Gigabyte K8NS Ultra-939. Go for it!
Also BIOS F5 is floating around and a link can be forund here:http://www.xtremesystems.org/forums/...543#post614543
It's not yet officially released and fixed many of the issues like the cold boot problem when overclocking. :) Try it.
Originally Posted by Bluesman_dk
sorry, havent checked back here...ive had it (booster) in 1,2 and 4 with ram in 3/4, 3/4 and 1/2 but NOTHING seems to get my old (BH-5) Mushies or the new (TCCD) anywhere close to what G-Skill can do in this mobo...270+ (dual/1Gig)
any modded BIOSs out there for the AV8? i really want my BH-5 in this thing...
Any news on the booster and any of the NF4 boards, or have none of them been tested yet? (Don't know whether you guys get any versions of the boards to test out before they are released)
How abt 2xSS dimms??? I have 2x256mb HyperX BH5 waiting for the volts.Quote:
Originally Posted by ElixXx
What's the deal with slot 3?? Why must it be there?
Can you please create a text base database in the first post?
It's too hard to find your mobo and the confirmation.
i just try OCZ DDR booster on ASUS K8NE but the LED doesn't turn on,there are no problem go to windows,the problem just the LED.now i don't know if this thing work on my mobo or not,somebody can help me?
Also would like to find this out :DQuote:
Originally Posted by Facedeharicot
Works on a SK8V, probably the SK8N too?
i've a big problem too, if i want to use my ocz booster and 2*256 A-Date nh5 it doesen't work but if i put one stick in , the ocz booster works fine , need help!
that means , i can increase the voltage on the two stick but nothing happend , no difference between 2.6v and ~3.9v , but with one stick and ~3.7v i can boot and run 32m @300fsb without problems, and it makes no difference which stick i use.
bios is 1.36b
It will fit with 2xSS if you pull away those tinycrappy heatsinks from Booster ;)Quote:
Originally Posted by clarence
If I put my Booster in first slot from socket, mobo doesnt boot at all
this is an issue with the PSU...not having a -5V or something...Quote:
Originally Posted by dimasdw
sure, and if you run 3+ V without sinks on thoes MOSFETS, youll be getting a new booster...cause the FETS fried!Quote:
Originally Posted by Dani
so how to solve the problem should i use another PSU?Quote:
Originally Posted by Joe Camel
:confused:
I have run it in my AN7, had to mod the heatsink so it would fit in dimm 1, because of a cap on the board, but it works fine.
okay now i change the DDR boster conection from conect with 1st PSU (without -5V) to 2nd PSU (with -5V) {i am use dual PSU }....but the LED only light on once when i turn on PC after that LED light off ,anyone have solution? :confused:Quote:
are there plans for a DDR2 compatable booster???
Using dual PSU?? Please try using one PSU with a -5v line.Quote:
I really don't know the answer. DDR2 is low voltage anyway. I'm sure our engineering department is looking into the possibilities.Quote:
Originally Posted by gclg2000
DDR2 cooks with too much voltage from what I've seenQuote:
About the DFI Lanparty Nf3 250GB.
Will it fit with 2 sticks of ram? i seriously doubt it will. Ive just got 2x 512mb of OCZ VX, and i won't be able to push it otherwise. :mad:
put the Booster in DIMM1 , then 2 other dimms will fit in nicely:)
Is that because it sticks out more on one side?
All the slots are really close together, same spaces? Are you sure?
Thanks. :cool:
Hi dose the DDR booster work on my EPoX EP-8KDA3+??voltage??
And if so dose i need 2 put my 2x512 in slot 2/3 ???
