ASUS AX800PRO VIVO flashed successfully
I successfully flashed this model using the modified flash tool and the modified 16 pipe PRO VIVO BIOS. I verified that I had 16 active pipelines, and I saw a jump in the ATI Tool 3d View from 115 fps to over 320 fps. I flashed back to my original bios immediately since the temp went to over 75 C almost immediately with stock cooling. I believe I need to flash with the Gigabyte flash tool back to my original BIOS, since I reset the card to its original configuration (12 pipes, 115 fps) with the modified tool.
