Originally posted by Iontach
Heres an interesting thing. I looked in A64 Twekaer and the ECC Mode was set to "Disable". But when I reboot and check the BIOS it says that all ECC options were turned on. Which one is correct?
Anyway I turned all ECC options off in the BIOS. Rebooted, started up A64 Tweaker, set CAS to 2 and TRAS to 6 and hit Set and it locked up again. When I rebooted I got a CMOS checksum error and had to reset the BIOS. :( This is not the first time it has done this after rebooting from a lockup caused by A64 tweaker.
Anyway, with ECC off I can now set TRAS to 6 but I still cannot set CAS to 2.
You say it looks like my mem can't handle agressive timings, but I am not trying to overclock the memory at all, merely to achieve it's standard speed so these timings are not "agressive" at all when compared to the RAMS advertised spec. This memory is supposedly garunteed by Corsair to run at CAS 2.
Should I start thinking about asking for a refund?
---edit---
Sorry I forgot to mention that my BIOS has no RAM voltage options at all. Are there 3rd party utils for tweaking that too?
Doesnt sound like you having much fun with that board :(
