Nice one :thumbsup:Quote:
Originally Posted by FDM
I had to fight for my 23.3k on the nf7-s last year :D
What cooling? You should definately mod your card! :D
tdx on the cpu, maze4 on the gpu, mcp600 pump, bix2 rad, beefy ramsinks on the vid card ram, still stock NB cooling
I will vmod hopefully sometime here, I need to find the pots/smd grabbers and borrow a dmm. 253x11 is do-able but it crashes to desktop too much to get a clean run in. Hopefully the -40F temps this winter will cure that :)
[mbot] tictac - 5962 - Athlon XP @ 230x9.5 ABIT FX5200 64bit @ 275/400 [/mbot]
http://service.futuremark.com/compare?2k1=8171493
[mbot] mars - 23795- XPM @ 238x12 9800pro @ 508/429 [/mbot]
http://service.futuremark.com/compare?2k1=7800780
Originally Posted by mars
????? Think you have a bit of a typo there :)
tictac, my first thought when seeing yours, was "wee, im not lowest anymore"
then, i realized in the 1st post, they only show the first 75... :( which we evidently dont make...
[mbot] wolfgang - 31221 - a64 @ 270x10 x800pro>xt @ 565/610 [/mbot]
http://service.futuremark.com/compare?2k1=8229017
[mbot] pik - 7726 - athlon 1200 @ 1.48ghz(10.5x141); sdram @ 141mhz; xtacy 9100 @ 297/277 [/mbot]
http://service.futuremark.com/compare?2k1=8102162
ha, yes! im #1 of the 9100 catagory :banana:
i think im a dumbass :p:
just copied and pasted urs lol
:rotf: ya my name is not on any rank as well.. guess my score to low :slapass:Quote:
Originally Posted by pik-ard v1.1
[mbot] FDM - 23624 - XPM @ 251x11 9800pro @ 486/411 [/mbot]
http://service.futuremark.com/compare?2k1=8183271
still trying to get 253x11 to make a clean run :(
@ pik-ard v1.1 from what i can see the scores doesnt get updatet either so whether your in top 75 or not nothing happens :rolleyes:
are you on phase change? Is the APIC still enabled? :banana4:Quote:
FDM........
i use this way to tweak my performance
open nV HardPage
go to Direct 3D menu
check for mip map details
set it to 24
i gain 400mark @ 5000+ level
if your previous score is 20000+ i'm sure it will boost up 1000-2000 mark.... ;)
no, plain water.. APIC enabled, cpu int enabled, etc etcQuote:
Originally Posted by tictac
set Mip map to 24... u will gain 1000+ mark... trust me... ;)
I take it nV hardpage is a nvidia tweaker.... I don't have a mip map option in radlinker.
ops sorry then... its for nVidia GPU only.... ;)
[mbot] aNaBolic - 30057.0 - P4 3.4EE 6800U [/mbot]
http://service.futuremark.com/compare?2k1=8184092
30k at Last !!!! Had 30347 but it decided to lock on publish and everything went weird, had to clock a bit lower to get a stable system. Even though Ive run 4.3Ghz stable for hours.
Need to do the hipro mods on my IC7 :)
PS. Makes me the highest 6800U on the list, infact it makes me the only 6800U on the list !! :banana: 11th highest 6800 score on the ORB :)
Also the highest IC7 :)
No hardware mods on anything :)
[mbot] Casey Chaos - 22043 - Shuttle SN95G5 XPC AMD64 939 3500+ 9800XT [/mbot]
http://service.futuremark.com/compare?2k1=8184084
yea, i know its not updating. but i had a 7.2k score posted a few months back, and that WAS up, untill 75 people beat me. :(Quote:
Originally Posted by Creep-DK
and, if you scroll down in the 1st post, you'll see a 9100 catagory, of which i am the ONLY person in. :D it has my old score... meh.
tictac, get them to add a fx5200 catagory. :p:
[mbot] spaceman 31066.0 A64 mobile 3000+@2619 Powercolor VIVO@XT PE @571/571 [/mbot] http://service.futuremark.com/compare?2k1=8183684
Can someone tell me what this is for? I mean is this a contest with prizes, or just bragging rights? I would think if it was for bragging rights, a thread with a compare url would suffice. :confused:
its suposed to be a team vs. team type thing... no prizes or anything else i think... but it does give us at XS the privelage to say we are part of the #1 3dmark team. ;)
Good enough for me. I was just curious, cause it's called a contest, instead of competition. :rolleyes: ;)
