its a thermochill 120.3 not a bad rad :) manages the heat. I may upgrade to tecs when i move to Dual Core which will be my next upgrade
Here is my current setup, but you can't see much of the WC hardware. The pump is MCP350, rad is Weapon 2-302+shroud, fans are 2 Sanyo Denki San Ace, block is MCW6002.
http://img.photobucket.com/albums/v3...everything.jpg
http://img.photobucket.com/albums/v3...tackerside.jpg
http://img.photobucket.com/albums/v3...ckerinside.jpg
Had to do something with the hdds, the rad is huge.
updated pic of mine. Sorry for the poor quality stupid USA made camera phones are horrible.
When my Asus mobo and X800XT are back from RMA I will update this
UPDATED
http://www.xtremesystems.org/forums/...id=26491&stc=1
Here's mine. Thanks maxx and everyone here for your help.
heres my setup swiftech mcw6002 dual 120mm rad , asetek vga block modded with 1/2" barbs , asetek res 1/2" barbs l30 pump and some sweet unbranded clear nice and flexy 1/2" id tube which cost a third of tygon. dfi ultra d , 3200 winnie @ 2700 x800xl @ 455 core 560 mem
Cool amp... Pimeta, PPA? :)Quote:
Originally Posted by cetoole
Pimeta, I built. I have Dynalo boards ordered.Quote:
Originally Posted by isp
Okay I'll throw mine in.
http://crainconsulting.com/DSCF0106a.jpg
http://crainconsulting.com/DSCF0107a.jpg
Hopefully I'l have all my ducks in a row and possibly have my external box up and providing real cooling.
-Brandon
What's the issue with the L30? grinding, vibration? If it's a "meat" grinder kinda sound then drain your loop and inspect your pumps shaft to see if its grooved. If it is Ive got a phone number to Hydor USA, they can get you replacement parts.
-Brandon
Hehe I just noticed you're in Europe, it then might be easier for you to contact Hydor directly since they are an Italian company.
hum, i got the same pump. it isnt worth to use it.
now i use eheim, i love it :)
Sorry Brandon, it's already too late 'cos it was my 2nd who did the same noise and too much vibratoin, too much heat and I just received my new MCP600 from Cooltechnica.
as a side note I'm new to WC and somehow I think is my fault so no worries, thanks for the offer though
New shafts corrected the noise I had in both of mine. Now all i hear is the in rush of air thru the vanes of my rad.
What are those 2 fans doing next to ech other on your rad?Quote:
Originally Posted by mad mikee
That setup doesnt really help imho.
Use PushPull instead of this (put a 120mm fan on both sides of the rad) ;)
when the first fan turns right and the secon left
its some kind of turbine ;)
haha yea the noise would be like a turbine :DQuote:
Originally Posted by caLume
It's probably just a shroud...
So the one on the radiator has the fins & motor gutted. My guess...
My new watercooling setup:
New Radiator(Watercool HTF 3 Tripple X with 1x Silent Fan and 2xAc Ryan Modding fans. Than i replaced my old Innovatek X-Flow with a pure copper block and i added the Gpu-X Heatkiller rev2 with mosphet cooler to my graphic card.
Got ~50C load under prime on my Cpu
and ~45C load on my graphic card, both ocled ;>
Will do a last update soon.. on the top of my case are many cables because i used many cable adaptors for the fans.. so i will get a fan controller that there aren´t so much cables and the system is also a bit quieter, maybe i will also get some new Ide cables because the ones from DFI are not twistable.
Dont wana sound like a mum but... when your pump fails and the water warms up the hoses warm up and the water expands so the hoses might come off..... :stick:Quote:
Originally Posted by dymONE
So i know your setup looks nice and clean, but aint it "wise" to put some hose clamps on there ;)
ps: are those blocks home made? Or what brand are they?
Your setup looks sweet ^_^
Psyche911 wins the boobie prize!Quote:
Originally Posted by Vandread
'Fan' Next to rad is empty and a spacer = no dead spot on rad :hehe: :D :lol:
@ Dymone - I hope the WB dead spot showing in most of your pics isn't constant? :eek:
Well, here is a pic of my WC system.
Its formed by Honda Civic radiator w/ 2xVantec Tornado 92mm, custom CPU Waterblock made by me, simulating a comercial design (Ketchak nº4) and home made waterblocks by p0stman, a Spanish waterblock maker.
The pump is a Hydor L20 (yes, this big :banana::banana::banana::banana: :()
In this photo, the system is mounted in an Abit KV8 Pro, 3200+ NC and 9800 Pro. Now it is mounted in a DFI NF4 Ultra D, 3200+ and Leadtek 6600GT, but without the chipset waterblock, because its hard to mount on the DFI NF4 and the mobo perform very well without more cooling in the chipset... :D
http://www.metamods.com/Imagenes//Prueba/Prueba7.jpg
nice setup there.. im liking the lights even though im not much one for bling.
http://img24.exs.cx/img24/8317/dsc002301zz.jpg
http://img24.exs.cx/img24/5624/dsc002317qb.jpg
My watercooling :) not so kick ass but i like it :) (very messy :D)
edit: pics to big, just click the links :)
Thanks for your advice but there are silicon hoses in my pc. These hoses dont extend with increasing temperature. And also good fit on the fitings without hoses clamps ;)Quote:
RePS :) : yes those are homemade blocks.
2 mad mike : its already resolved ... i had to lean my case.
Are you kidding me? It's not messy! Maybe busy but it looks nice. :DQuote:
Originally Posted by Suffocation
