Try vccsa at auto, 1.0 seems just slightly high.
I decided to start all over back from the beginning. I am doing something terribly wrong when it comes to manual settings.
I say this because leaving voltages at auto (besides vcore at 1.285v) and disabling fastboot as suggested....ZERO Problems. 4.5Ghz with the uncore @ 4.5Ghz as well. Stable, no cold boot issues.
Not sure which manual settings i configured were giving me the problem.
Hardware is fine lol it is me that is the problem. Appreciate everyone's help/patience/input.
/plays tiny violin.
Side note: Heart stopped a few times seeing "00" post code but cmos reset always fixed it.
Who ASUS X99-A and X99-Delux, also has a dispersal you can look in AIDA or somewhere else VRM temperatures in idle time and in loading... Simply on my X99-A in idle time 60-68, and in loading 80-85...
Welll done Dumo those scores on Cinebench R15 are Killer !!!
My 24/7 Rig and Bench Rig also
http://i.imgur.com/BuZ4zqn.jpg
http://i.imgur.com/2Co3Ret.jpg
Cheers to all !!!
Sergio
Almost done :)
review of R5E: http://www.xtremesystems.org/forums/...treme-part-one
memory tests: http://www.xtremesystems.org/forums/...77#post5242077
PS: very nice setup Sergio, I like your PC :)
so I picked up a x99 system last night a 5820k corsair 2800 lpx ram a rampage and been troubleshooting ever since my 3 290x refused to play nice either 2 worked in cfx or just one alone.i eliminated os and drivers by backing up my main drive and doing a fresh install of win7 still same issue with multiple drivers All three have full cover blocks on them so they i can test is with the pcie dip switches all 3 cards work fine by themselves and in dual cfx but when loading win after the splash screen it'll just go all black and freeze.
so after tearing my hair out i dropped the slots gen down to 1 and the system booted ran a game and some other tests then rebooted and upped the gen slots to 2 i did this till i got back up to three and its been booting ever since. It almost feels like it fixed itself which i dont feel comfortable with but long story short right now its doing occt at 4.6 and 4.4 uncore. 1.350 vcore 1.370cache volts seems like its finally working so imma play around and see what i can get out of it..
is the second 4 pin power supply on rampage v extreme necessary to be plugged in ?
With a 5960X overclocked with over 1.25Vcore and fully loaded, it's a good idea to use both the 8 pin and 4 pin.
MSI MAX: nice :)
thanks Flanker i think i got all the bugs sorted out #teamnosleep
Raja what about 5820k @ 4.2ghz
My 5960x nr1:
so, with 100 BCLK I got max 4300 MHz stable. Cache 4000 MHz, DDR3 3200 MHz 15-15-16-35-1T.
CPU voltage 1.321V
Cache voltage 1.35V
SA voltage: 1.05V
max temps: 85-93 C (depends at cores)
cooling: Noctua nhd14
Now I will testing 125MHz BCLK and Im looking forward, if some changes in top stable clock....
i encountered the same issue again when i had to reset bios to optimized default settings when going into windows 2 of 3 cards showed up its only when i go back into the bios and set the pcie slots down to gen 1 boot and bring them up in order back to gen 3 that all cards get detected
Interesting bug...Did you tried another version of BIOS?
not yet flanker it has the latest tho
Ran. 2 x 290x no issues yesterday. Can you try disabling ulps so cards don't auto throttle slot speed and power. Maybe driver or Windows issue
today I got semi stable settings a bit higher. Really, really hot...4376 MHz with 1.35V at CPU, CPU temps around 94-102C ... This is my max what I can do with Noctua NHD14
hey splave 2 cards work fine it just wont recognize 3 without jumping thru hoops and its usually the second slot that does it but ill try that when i get home
DH-14 is way abused by situation,try a liquid AIO,Thermaltake Water 3.0 extreme is very good,managed to keep the cpu at 1.42 in prime95 without thrtotting,max 90 degrees,great cooler
