Originally Posted by
Alex-Ro
I think you guys are setting VCCIN too high for air,i saw no gains above 1.9 honestly,on air...
Played with dice and used 1.7 vcore and 2.2 vccin,high dram voltage,tight latencies,whatever,cpu survived for 6+ hours at -70.
For testing cpu/binning under cold i would start with a vcore of 1.7 and 2.2 vccin as a base,then see if increasing vccin actually gains something,no point in jumping to 2.5 vccin from start...Start lower with voltages and see where the curve gains/voltage ends,unless of course you some old QE6S ES chip that can handle 2.5 vcore no problem :D
Also don't forget about temperature compensation option from ln2 mode ;)
