Thank you, Siren. I'm choosing the Raystorm because it performs good enough, and it has some LED bling going on that matches my build. :up:
Just when I thought I was out... they pulled me back in...
http://youtu.be/G29DXfcdhBg
3 more blocks coming now lol...
Can't thank you enough for the hard work, Keep at it!
Finally got some flow rate testing done on the blocks. I realized its kinda hard to tell which is which because the legend isn't in order of flow, so here's the other plot to compare with if it helps:
http://i.imgur.com/6aAX4j0.png
http://i.imgur.com/VwRDI.png
FIXED with the legend in order of restriction :)
Very helpful charts. Thanks a bunch for the extraordinary effort. :)
Awesome work as always, thanks!!
Fixed the order of blocks in the legend and added a helpful arrow :)
Now to buy haswell and do all of this over again :rofl:
Soo..what are the 3 newcomers you mentioned if that's something you can share?
Just curious. I have a very old prototype block someone sent me many moons ago that needs testing too. The design is rather unique. From the 80s I believe and uses some sort of special ultra fine microchannel design with a unique parallel jet system. Kind of funny that it's so old yet so advanced in design. Who knows it may even still hang with the best of them.
Need to fabricate a hold down for it though, has some funky oem bracket system.
Hey Martin - Well I'm not sure what's going ahead and what's not to be honest. There was a new manufacturer's block that I had tested a prototype of and they seem to have disappeared now. I'm not sure what I'm allowed to say so I'll keep it generic for now. I'm supposed to have two revisions from existing manufacturers coming in. I heard rumors of a third and I also saw a pic of the phobya uc2, so I need to talk to AT about that last one. So possibly anywhere from 0-5 blocks coming in lol. I'm really not sure what's going to happen though because some were mentioned a while back as shipping that day but never showed up and still waiting on a response!
Sad to hear that DT shut down too :( I really liked the quality of Erik's blocks.
Nice..success! Your work in my opinion is by far the best current data out there and as usual it has promoted competition and further advancement.
Look forward to MOAR if you have the will and ability to continue keeping the test bench static. Really enjoy seeing the pressure drop addition as well as the Dt vs pumping power charts. Icing on my data cupcake..loving it!
I see PPC's carrying a new EK-JET Supremacy J4 Jet plate J4 yields up to 1?C lower temperatures on Intel LGA-2011 platform --> H E R E
Yeah I tested the prototype here: http://www.xtremesystems.org/forums/...acy-Jetplate-4
When I get the real thing I'll include it here :)
Well if you want a super low restriction block you best jump on the last few IceForces because MIPS has gone out of business :(
Why do you post results in water temp and not CPU temp? The point of a CPU water block is to remove as much heat as possible from the CPU. If the radiator stays the same (method of cooling the water) and the CPU heat output stays the same (method of heating the water), then shouldn't the block that results in the highest water temp technically be the best?
Just to make sure nobody takes this the wrong way, I'm not saying anyone is wrong, just thinking out loud/starting a discussion/looking for answers... Also, if this was already covered somewhere else can someone link me?
I think it's more to do with the signal to noise. The temp sensors will not be accurate enough to measure the delta temperature between in and out of the cpu block accurately enough to seperate blocks the same way. Often it's only 1C across the block, so if one block gave you 1.01C and one gave you 1.02C it'd be really hard to know that that measurement was accurate.
Is the cpu temp difference that small between blocks? I've never tested this before so I don't know... btw I'm talking about cpu temp as displayed by realtemp or something similar so we're on the same page.
The results on the first page show a delta of 6.97 from best to worst block, was actual cpu temp difference only in the 1 degree range?
Oh - then we're talking about completely different things. My results are cpu temps measured by realtemp relative to the coolant temperature.
I thought you meant why not just measure the delta between coolant in and out of the block in order to get rid of any bias in the onboard temperature sensors.
So are you showing actual cpu temp anywhere? In my mind the best block is the one that results in the lowest cpu temp independent of water temp. Is there something I'm not taking into account that puts a flaw in my logic?
CPU temp with coolant subtracted is a far better indicator. If you just look at cpu temps only then you're not taking into account how your ambient air temperatures change during the course of testing. If you subtract air temperatures then you're then also dependent on your radiator and how it performs vs flow and whether it gets blocked with dust over time as well as yet more second order effects unrelated to the cpu block.
A cpu block takes heat from the cpu and dumps it to the water. The only fair way is to measure the cpu temperature and the water temperature. As soon as you measure it relative to anything else (even "nothing" i.e. absolute zero) then you're looking at the performance of more than just the CPU block. Does this make sense?
This is why any review of a cpu block that just looks at pure cpu temperature that is not relative to coolant should be ignored even if they claim they hold ambient steady. The amount of variables mean testing errors will be way too significant. Now if you're testing a whole system vs another system, then you could measure vs ambients, but you still need to measure your local ambients coming into your radiators accurately. If you're not measuring ambient or coolant, then the numbers are basically worthless.
Oh, I see. I wasn't taking ambient temp, dust, and fan performance into account in my thought process... Thanks for explaining
So when do you think you'll be testing Haswell?
Honestly probably not until late july!
looking forward to it! thanks for testing all this stuff for the community!
Yes water temps will be affected by those things, but the CPU temps relative to the water temps won't be. The CPU temperatures should only be affected by the water temperature. Yes there will be small secondary ambient effects due to secondary cooling paths (socket cooling), or due to poor linearization of internal cpu temperature sensors. But those effects will be small. If you measure relative to ambient or relative to -273K then those secondary effects are much much larger.
If you are effecting water temperature, then of course you are effecting the water to cpu gap. The reasons you give of why not to measure ambient temperature directly apply to measuring the water temperature. It wouldn't be such a big deal had you not took a dig so hard at everyone else ;)
