Have any laptops shown up for sale yet? Or is aint they coming until June?
if someone has to go to the store to get ram added, the sure dont know that dual channel will make a difference on their apu performance. its the OEMs job to do that right, and its quite odd that not even one company out there would, and then advertise they do it right for extra sales. or that amd dosnt tell them to.
I was talking to you.
I can say the same thing to joe average (as long as joe did a little research or at the very least watched a tv shopping channel for 5 minutes) and he will get it too. "I doubled the memory in your computer from 4GB to 8GB, and the memory speed is now twice as fast as well because there are two highways for information to travel. Now, that doesn't mean your laptop will be twice as fast, but it does give the processor more room to move information from place a to place b. Anyway, manufacturers don't like it when you mess with the stock config, so if there is ever a problem with it, make sure to open up that spot right there, and take out one of the memory sticks."
"Okay."
IPC ITX board from Jetway for Trinity (Comal) APUs.
Attachment 127152
Attachment 127153
does it have 2 x mPCI?
So,FM2 and still A75 chipset?When is desktop trinity going to hit the shelves,mid july is a realitic date?
FS1r2 socket, Comal the mobile platform for Trinity.
The chipsets (A55, A75) can work with Trinity no problem, however the motherboards need some 'TLC'.
Extra crystals, PLLs and such ;)
There is also some speculation of a new A85 chipset joining the lineup as well, specs are still unknown.
FM2 Trinity (Virgo) board based on 'Hudson D4' (A85) FCH.
I have no specs available for this but I assume the FCH is A85 since there is 8x main SATA connectors and A75/A55 only support 6x.
Attachment 127256
Nice!
Very clever placement of the mini-PCIe.
DisplayPort + HDMI + DVI + VGA - covers every possibility.
I wonder which ports can be used for EyeFinity setups with 3 screens. Does HDMI + DVI work or is one or the other?
Soo whats with the placement of holes for heatsink mounting on the Jetway and MSI boards?
FM2 uses the same mounting hole pattern as Socket 940>.
MSI FM2 motherboard made for HP (by Pegatron) use customized pattern.
nice Stilt, I hope, Computex show us more motherboards of FM2
A85 board from ECS:
http://www.techpowerup.com/166974/EC...M2-Socket.html
