Made a simple chart illustrating the relation between VID and power consumption based on some of the FX-8150 chips I got.
Naturally there is variation even between chips with the same VID. For example those 1.2875V VID chips in the chart probably came from the same wafer.
Iīm not going to tell the frequency or voltage I tested the chips with, but the conditions were identical between each chip.
The Pmax is for a whole node (4CU/8C, NB, Logics).
http://img526.imageshack.us/img526/3423/fxpmax.jpg
The 1.2375V VID chip is a newcomer.
Runs hot as hell but does 4.2G Prime95 LargeFFT stable with the stock voltage.
4.5G requires 1.31V, 4.6G 1.35V... After that 2nd (0-3) compute units starts failing due heat.
With 1.35V the chip reaches 70c easily with Ultra Kaze 3k rpm fan blowing at full throttle. How intense :D
Pretty strong NB it has, 2400/2400 (DRAM/NB) is fully stable with just 1.125V, 2400/2600 requires only 1.20V.
Havenīt tried 2800 with lower MEMCLK yet, that might work too.
