Phil maybe I missed it but why are you not using the entire reservoir? Also if you were going to only use one side why did you choose the side that has previously had bleeding issues? Just curious? I read in your previous posts that you wanted to do the pumps in Series. Did something happen to one of them or was this just simply a test to see how well the new revision was set up for bleeding on that side? I have the same 1.3 version and currently am just running one D5. I have the reservoirs joined and have the pump placed on the opposite side that you do.
