ufff, dont seen it before, srry, nice busspeed clock! Nice...1.37 4 Ghz stable? Great. Is the same chip as at your HWBOT validation?:)
nop, it was 1021.
c4f died and took my lovely 1021 while running wprime on 1.86v :(
Really nice AMDnord :D
I mean how? Too much burn?
For one or the other to die (motherboard or CPU) is bad enough but when they both die together:down: That has happened to me several times lately and I'm getting down right gun-shy:eek: I wish I knew why they both die at once so I could know what to watch out for or not do.:shrug: No, I know what you're thinking but not over clocking the hardware doesn't work for me as a fix.:D
I figured out a way to get the latest Lucid driver to install. I have to manually uninstall the previous Lucid driver then restart and install the new driver. Hopefully Lucid releases a new driver soon to support the latest nvidia driver so I can use my 570 and 470. But I have also had 4 new BSODs in the last 2 days one being the tcpip.sys. Just thought that I would give an update.
http://img716.imageshack.us/img716/1305/s6303076.th.jpg
http://img831.imageshack.us/img831/8585/s6303077.th.jpg
Uaaaa, will be testing with x6 1100T BE :).
FlanK3r let us know how the testing goes ok?
DexNfX: ok, givew me some days. Im working at it, but seems it very good ,-)
Messing around with two 6950's and a 5870 trying to get them to play nice. But having some issues..
So far I've tried pcie slots 1+2+4, 1+2+5 and 1+3+5. Lucid driver versions 1.7.105 and 1.6.109 +cata 11.3, but slave cards will just sit at idle clocks and do nothing in 3dm11. Lucid software says all is well and working and can get the overlay to show etc.
Any tips are welcomed :)
Anyone still having BSOD issues besides me. There is only 2 that I ever get and those are tcpip.sys and eq1sx62x64.sys. Never anything else. This only happens with continuous network usage which is required for what Im doing. Mostly its a low amount and not a problem but when there is a more moderate level of usage it become hit and miss for stability. It can stay stable for quite a while but can still crash randomly with a moderate level of usage to the network so even regular downloads like drivers and the like I get nervous because my system could crash. I have plenty of crash files because of this. I just wanted to see if anyone else was also still having these here and there. I will say the fix they did a while back did fix the issue a lot but does not effect high levels of network issues which its still unstable.
