3845A935 Xeon W3520. Cooling Cogage Arrow 2x140 push/pull
http://img163.imageshack.us/img163/1106/4500l20o.jpg
http://img256.imageshack.us/img256/9632/4500loud.th.jpg
Angelreaper can you make me a favour and try to run linx with problem size set at 25000? I want to check if it makes any difference at the vcore required to be stable. Nice job and great cpu you have there :up:
hi
final got to test with linx
Nice low voltage submissions, guys! Keep up the good work! :up:
here's mine:D
4.6 06no ht
4.5 23with ht
megahalems push pull
i be back:D
Nice! Whats your batch #?
Sorry but 11500 problem size is very low to stress cpu. Try again with at least 25000 and post back.
From what I heard you claimed it to be 4,6ghz HT ON stable?
That's first point. Second point is, without using at least 4096MB of used ram don't even try, otherwise it's too easy. 7 minutes of testing is nothing, but :banana::banana::banana::banana:.
Try one hour, it will crash :) Don't blame us, you were the one claiming 4,6Ghz ht on stable on air.
I hope he does come back I want to see his desktop again!
@ johnksss: very nice! :D
What cooling did you use?
yes, water cooled.
water chiller, i think...i cant remember. and like a dummy, i forgot to put a side note.
ok, i found it..yeah it was a small water chiller and water was at 60F
i never claimes i was stable 4.6 ht on ;) learn to read
cpu can prime like its nothin so go find yourself an i7 that will do 4.5 with ht on and try for yourself
maybe 1 day you will:rofl::rofl:
dont hate cause your i7 suks
Zalbard i be ready next time when i get more free time to duct the a/c to the intake fan;)
Learn to not brag on the forums before you actually did something.
I never tried to have 4,5HT ON, and like I said before: 4,6 HT ON ON AIR is almost impossible. And you were the one claiming you've got that cpu capable of doing it. You failed m8, since I can't see 4600mhz ht on in the pictures.
Actually you don't want me to upload screenshots of an i7 doing 4,8GHz HT ON linx stable that my friend was running on SS. So better don't say "maybe 1 day you will". Instead of that upload your 4,6ghz ht on mr. fail.
before you have another brainfart
i never stated i used ht
that was first time i even completed passes linx on ht
so dont start puttin words in my mouth and drop the crackpipe
and if i wanted to do 4.6 with ht i can all i need is proper coolin cause i know the cpu can do it
maybe i should ask god to gimme his linx pass @ 6.0 :rofl:
Guys, please, take it to PMs.
Thank you. :up:
I am sure i can get my i5 750 to pass linx 20 pass with 12gb of memory at 5ghz with ht on, it might just need alot of ln3
Chill the attitudes, now.
Done about 10 days ago quickly...
CPU: Core i7 920 D0, #3849A832, 4650.5MHz (222MHz x 21, 221.5MHz actual), With Vdroop, 1.611V idle, 1.541V load, HyperThreading On, 3987MHz Uncore, 42C idle, 89C load
DRAM: Mushkin Ascent Redline 6GB 6-7-6-18-59-1T 1600MHz kit at 1772MHz, 7-8-7-18-59-1T, DRAM Ratio sub-timings, 1.67V
MOBO: EVGA X58 Classified E759 with EK FC block
GPU: MSI R5850 OC at 1.225V/1000MHz/1250MHz
COOLING: Water with a single HW Labs BI GTX360 cooling CPU, motherboard, and GPU(s), 23C ambient
http://img.techpowerup.org/100226/46...n_LinX_20X.jpg
