hi guys.
i bought Triple Channel G.skill perfect storm 2133 cl9
i will know what's kit?
http://shahrsakhtafzar.com/img/out.p...MG0015copy.jpg
hi guys.
try them they are good
pt1t got 2000 cl6 with them ;)
any results with 15000CL9D ripjaws or idea what chips are under the hood?
:up:Thanks for the testing Benji. Please show some more results for the Trident and 1600 7-8-7 Ripjaws.
Hi Benji,
how are you ?
very nice result :up: i waiting your result in c6 and c7 To compare with my Trident!
for this money Gskill have made a good job :clap: !
Sorry guys, i don't have any screen to show you right now, because i'm working on other things, but here are the results of Trident 2x2Gb 2000 C9 and Ripjaw Blue 2x2 1600 C7 :
http://img4.imageshack.us/img4/5039/dualk.th.jpg
Speaking about 6-7-6-18/7-8-7-21/8-9-8-24 always 1T tRRD5 tRFC72 vdimm 1.65v, LinX 64bits
Jagva > This is not the right thread, but PS 2133 are good enough. I got some 1080 C8 1.65v rockstable and around 1000 6-8-6 1.7-1.75v
what about the gskill trident 1600mhz cas8 2x2gb kit ?
i can see that gskill removed em from his site
i have just bought this kit :) but only now see this :O
2160 Rs 9 9 9
2000 rs 7 9 7
linpack at over 2200mhz...
nice kit :O
ripjaws 2000 cl9
is it worth putting Ripjaws in system with p45 chipset?
p45 = ddr2.
These are ddr3.
There are P45 ddr3 mobo's, my EP45T UD3LR loves low voltage rams... but loathes my micron GTR's
guys
how command rate with this ram and i7?
i have more more problem with my p55a ud5 and this ram, my pc freeze after 5-10 minutes in win but i don't know if it is a motherboard problem or ram setting
at 1333 9 9 9 it can pass 400% of memtest from boot ...
what is the standard setting on ram?
i use this kit at 2066 1.64v 9 9 9 24 1t stable with memtest
@ 2000 mhz can i set 8 9 8 ?
http://www.newegg.com/Product/Produc...-306-_-Product
Anyone know if this RAM is the same as the stuff in the OP (Elpida BBSE)? It's the same specs but only difference it is 1.6v not 1.65v.
Brand G.SKILL
Series Ripjaws Series
Model F3-16000CL9T-6GBRH
Type 240-Pin DDR3 SDRAM
Tech Spec
Capacity 6GB (3 x 2GB)
Speed DDR3 2000 (PC3 16000)
Cas Latency 9
Timing 9-9-9-27-2N
Voltage 1.6V
ECC No
Buffered/Registered Unbuffered
Multi-channel Kit Triple Channel Kit
Are the 4GB kits the same ast 6GB kits in terms of ICs?
I've got 8GB (2 x 4GB kits) but switching to X58 board and wanted to pick up a 3rd 4GB kit for 12GB total. Anyone foresee any issues?
I just ordered kit of these, looking for some nice bandwidth action :p
does ripjaws use same ics as trident?
hi devil i think the g.skill staff can ans to you -->http://gskill.us/forum/showthread.php?t=1878
tnx ^^
now i run my ripjaws at 2066 8 9 8 24 1t
very easy ... good kit :)
after test i will post screen of linx+memtest+prime95
