I was hoping you'd say that.
Sorry to be a nag, but could you possibly post or link some pics of the tops?
So here is a little update that I am putting out on all of the forums.
The lights have still not come in yet. Both Performance-PC's and FrozenCPU have told me that they are waiting for them to come in any day now.
I now have two new aluminum color options. Smoke gray and green anodized.
I have switched over to using acetal disks for the ends of the reservoirs. The sheet of acetal I got is good for about 121 disks, and is being sent out for laser cutting.
I also have switched over to using cast acrylic mounting clips, rather than these black thermoplastic ones from McMaster. The black ones have shown to be way too stiff, and it takes a ton of pressure to get the res to snap in. I am afraid over time, snapping the res in might cause it to crack.
So please bear with me. You will all not be disappointed with final result here. I am really trying to get these to become the highest quality possible.
My ultimate goal is to get to the point where I can make modular reservoirs. Have the acrylic tube threaded. Have one end cap threaded with the light tube, and have the other end cap threaded with the helix attached to it.
Questions, comments, suggestions while we wait for some lights and laser cutting to be done?
I'm happy to wait. Honestly, I wouldn't be that pissed if I only receive this in December [but try not to do that lol]. Could you post pics of these new caps?
Well the time means I have more time to save up some dough to possibly get one. I don't usually spend extra just for bling (and my EK res works just fine) but I'm sore tempted on this....
Frozen, you gotta do what you gotta do.. It's better for you to change it up, and figure what's needed now then to get the countless e-mails or calls saying your product just messed up their 1k system.. I will be one to say that I do believe in your craftsmanship, and I can't wait to falunt your res all lover the forums. I know my project log at TPU is waiting on this masterpiece to be done!
Yep exactly, and I thank you all for your patience on this.
In the meantime, I think tomorrow and Tuesday I will work on my website a bit, maybe post some pictures on here of the different aluminum colors and such.
Sounds good to me. Maybe work on finding UV purple acrylic tube stuff! :D
I cant!!!! I've looked everywhere.
The only possible thing would be to do hollow acrylic tube, wrap it in the helix, and fill it with UV reactive liquid.
Not sure if this is what you wanted but check these out:
http://www.tapplastics.com/shop/product.php?pid=490&
http://www.tapplastics.com/shop/product.php?pid=143&
I looked into using that but that would only be for the outer tube. That purple isn't UV reactive either, only the red and green is.
Frozen: Is it possible to get one custom made? (i may want one that aint so tall for my SSF build)
Yep, absolutely.
That is the coolest thing I've ever seen. :D
Still waiting on the lights...
Also, I am going to keep using the black clips for now, I will just mod them all to cushion the reservoir. I was quoted $6 a piece for having the plexi ones laser cut. A little much compared to the black thermoplastic clips which are $2.12 a piece.
Lights are in stock and have been bought!!!
Yay :) Can't wait to see finished reservoirs.
(not sure why I wrote projects the first time rofl, need to go to bed).
frozen how long is the inverse res i was hoping them to be the size of ek 150 res
they are the size of an ek 250 res...but I can make them shorter easily.
Lol.. Nice one man! Very nice. Glad to see it all come to an end in the next few weeks for ya! well some of it. Best of luck my man!
Woohoo ccfls inbound.
Now lets just see how long it takes for this Delrin to get laser cut...
I can hardly even wait, you cannot make these things fast enough for me:)
how long in inches are the standard inverse res?
are these the same width around as a normal EK res etc? just starting to figure out placement etc want to make sure i got enough room for it where i want it.
also any updates?
was hoping to get it for a bday present but thats not looking likely (11th of july)
but i know its gonna be worth the wait!
