PCI-E 104 is max you used? If so try a bit more.
Major Update To The First Page
Let Me Know What Ye Think and If There Is Anything Else That Ye Want Added Let Me Know By PM
Raptor1
has someone tested a Xtreme Cooling setting in BIOS and by jumper? Is this the same? I am ready for LN2 session, but i dont know what is better ...
PS. CSC Strap jumper is not working NOW, it is feature for future CPUs ...
I love this board and cpu, W3520/760/Corsair GT cas 8 6Gb, and 2-Sapphire 4870x2 with Swiftech Caldera water blocks with modded bios no volt mods. Most of these where done on the OCZ Cyro Z but I did try the F1 Kingpin pot once I seem to have a coldbug around -68c so not much better scores or clocks than the SS. This is Windows 7 64 bit RC1 no tweaks...
cpuz
http://img3.imageshack.us/img3/9344/cpuzdij.jpg
superpi1m
http://img6.imageshack.us/img6/8950/signatureimgh.jpg
superpi32m on water cooling
http://img3.imageshack.us/img3/30/superpi32m.jpg
wprime32m
http://img3.imageshack.us/img3/3963/wprime32.jpg
wprime1024m
http://img3.imageshack.us/img3/360/wprime1024.jpg
pifast
http://img3.imageshack.us/img3/1128/pifast.jpg
AM3
http://img3.imageshack.us/img3/9027/am3l.jpg
3DM01
http://img3.imageshack.us/img3/3755/3dm01.jpg
3DM03
http://img3.imageshack.us/img3/7913/3dm03.png
3DM05
http://img3.imageshack.us/img3/3258/3dm05.png
3DM06
http://img3.imageshack.us/img3/1271/3dm06z.jpg
With water cooling, I have a couple SSDs coming to try to improve PCMark :down:
http://img3.imageshack.us/img3/4647/pcmarkvantaget.jpg
http://i42.tinypic.com/2itslrt.jpg
What a difference cold makes :up:
ill give her a shot, what exactly do they do?
EDIT
Whatever it does it 5.11
http://valid.canardpc.com/show_oc.php?id=577360
lol
@ raptor1 Well done on the changes to the first post!!
@ Bobbylite Very nice!! Can't wait to get home and throw mine under the SS.
so has anybody done 2100 4.4ghz stable with prime95 say 8 hours or so??
still havent seen anything spectacular on this mobo for high stable clocks with high dram speed..
i did 2 hours..my post is back a few pages..i am not a supporter of 8 hours...to many variables can upset the apple cart even with 8 hours under your belt...i say just do the minimum that you would be using the machine for video games or whatever..if you are talking about folding, you would be crazy to do that at 4.4 ghz...if it was me, it would be a very mild overclock to do folding.
I am tempted to give it a shot with my W3540 after I get my RMAed dom GTs back . The thing is though I am on air, so I am a bit hesitant to run 8 hours prime with that kind of heat it would be generating.
I think that it could be done only with higher binned Elipdas as they seem to require lesser drive strength and most probably only with Xeons as they seem to have better IMCs than the 920 D0s.Just my :2cents:
EDIT: Did you try loosening tRFC?
Setup:
http://i125.photobucket.com/albums/p...i/IMG_1385.jpg
24/7 settings..
http://i125.photobucket.com/albums/p...nchmark2-1.jpg
heh i dont break 70's on linX and this is with 22-24C ambient.
I was about to buy the Classified board today and then saw this in stock and now can't decide!:
http://www.newegg.com/Product/Produc...82E16813131390
I had no problems overclocking on the P6T6 and was able to get my C0 920 to 4.4ghz without too much trouble...I will probably still get the Classified just for high BCLK.
This is maybe a stupid quest but I ask any way! ;)
It does not effect the performance if i put my single GTX295 card to PCIex 2 or 3 instead of PCIex1, Right?
I need that space to cool my chipset on air.
pretty sure you have to use the top slot if you only use one card, atleast thats what I was told by evga when I was having issues with my pci-e slots.
"Did you make sure the card is in the top PCI-E slot because it needs to be"
