seems to fix the cf htt clocking issue i have now 230 and 1840 on the ram
213htt was the max and nothing over 1640 when booting from bios
Where can we get this and does it unlock the 4th core?
bios was sent for testing and i dont have a 720 atm
That ashame t1 looks abit better!
fixed command rate now when set 2t it shows in windows cpuz
I found that out with F3i was limiting my mem speed! What the max mem speed you had with t1 bios!
bios still needs dram drivers weak mode setting in the bios mem page so we can set to weak
1880mhz checking stability
I guess the bios still needs tweaking then!
http://img25.imageshack.us/img25/966...shot048.th.png
http://img15.imageshack.us/img15/386...shot056.th.png
http://img11.imageshack.us/img11/282...shot057.th.png
http://img8.imageshack.us/img8/6935/...hot061v.th.png
http://img17.imageshack.us/img17/884...shot062.th.png
http://img10.imageshack.us/img10/125...shot063.th.png
http://img13.imageshack.us/img13/925...shot064.th.png
I'm tempted now!
Once RB-C3 will make it's way into retail I'm switching to AM3 and next Gigabyte board.
Has anyone got a link to the new t1 bios! Have been looking allday!
I am with you!
Which memory is the best for this board?
i think that's it for my 4 cores
http://www.shrani.si/f/2F/zQ/3qMrCA9G/cpuz.jpg
the giga board will be the first victim of cfx with a v8 turbo under the hood
http://img25.imageshack.us/img25/765...1474088495.jpg
http://img16.imageshack.us/img16/786...1454067186.jpg
the v8 is modded with a delta 150 cfm
http://img16.imageshack.us/img16/733...1484647568.jpg
By deeodee
why is my ram working 64bit mode, shouldnt be 128
128 ganged and 64bit unganged it can be changed in mem setting in bios! 64bit is meant to be better they say!
Hey everybody,
I have a problem with RAID0 and Windows Vista64 Ultimate this motherboard with the SB750.
I have 2x320Gb Samsung F1, but when installed Windows Vista64 does not load the files in the folder SB750V/LH64A
I have to load the x86 version, then it detects and installs the Raid, but after installing windows the BSOD error.
Someone had this problem?
Excuse the bad English, but I am Portuguese.
You need to load Vista 64 SP1 with the native Windows drivers, then update the system with these drivers - http://support.amd.com/us/gpudownloa...3&lang=English
You are loading the wrong drivers off the CD, the x86 drivers are for the 32-bit operating systems.
Download the Drivers, and unpack.
The Drivers to view this directory are
C:\ATI\Support\9_3_vista32-64_raid\Packages\Drivers\SBDrv\SB7xx\RAID\LH64A
But when loaded by Pen USB Windows Vista64 says that is not compatible ...:(
If X86 version gives, but then gives BSOD after finishing the installation
I need help...
Works fine with windows 7 64 using usb pen by taking raid drivers from disk under SB750V and then LH64A if you cant get vista 64 to work!
