Thanks, So you mean I need to set uncore to 3200mhz, at the moment on auto its defaulting to 2133mhz, what difference will bumping this setting upto 3200mhz make, not sure what uncore is or does.
Below is a snap shot of CPU-z and Foxconns software before the change to 3200mhz,both pieces of software reading the ram as 1067mhz when they are set to 1600mhz in the bios.
http://img190.imageshack.us/i/capturewcr.jpg/
And now after the change to 3200mhz, Foxconn software says RAM is at 1600mhz and so does CPU-z:
http://img194.imageshack.us/i/capture55.jpg/
Thanks for your help, i'll be off too start overclocking this baby now.
