I have plenty of method to recover a BIOS including a programmer, but its hard to program a chip you don't have the info for because its not been printed on the IC, hence the hotflashing method.
Should be all the info you need. I've programmed the chip several times.
A25L080
http://www.amictechnology.com/pdf/A25L080.pdf
All done and TPower is back online :up:
Dude seriously, did anybody ask you? didnt think so if you doubt KETS abilities dont do it, if you dont have the board, why are you here?
seriously all you've done is thread crap every post in this thread and cause crap nobady cares about. dont flash if you dont want the risk, even a "good" bios can cause corruption when flashing.
many MANY could be in these bios, again with the thread crapping.
agreed, at high fsb even with dry ice, i have had this board give me the 96 error and had to hotflash so it very well may have some issues, still dont know why it does it, thank god for spare bios chips.
GUY'S what alot of you are failing to see here is that KET HIMSELF is providing for some a great favor that he does not need to do. HE is attempting to fix some peoples prolems and all you guys do is crap on him about it! That is rediculous. IF you do not want the service dont come to the thread if you have doubts DONT FLASH.
You need to set the NB GTL to .64 with a quad for FSBs over 400 or so.
FYI if anybody gets a "dead" TPower, put the TPower BIOS on a floppy (a USB stick might work too) and rename the BIOS AMIBOOT.ROM, the floppy\USB doesn't need to be bootable. Turn the PC on and the file will be read, after a bit the system will shut off, DO NOT REMOVE THE FLOPPY\USB, continue to wait and after a few more moments things should be revived.
USB Key or CD-Rom does not work.
try a floppy, maybe try making the usb stick bootable, KET where did you find this out? is this the bios revive thingie?
funny, the bios service man is 80m from my home away :D next street to me :D 7 euros i pay fpor my new bios on the chip,puhhhhh
maybe i should buy a second chip to have one here
www.jumperz.de
this is the shop, i can see his house from my window:D
Right On, Brother!
Well folks, my TPower is gone. Someone made me an offer I couldn't refuse so I waved goodbye.
i try other rams now white mushkins. they wont get over 1100 too :( is it possible, that any controler or something like that on the board dont wanna go ram over 1100mhz?
edit
FFS as Phil has already said, I'm attempting to fix things, its more than Biostar are doing. I warn of any BIOS code I haven't tested but if somebody chooses to use it still and runs into problems thats their fault for not heeding the warning.
Bottom line: Stop :banana::banana::banana::banana::banana:ing and just wait for a final version BIOS I have tested if you don't want to try a beta. Next you will be saying its irresponsible of manufacturers letting users flash to beta BIOS versions, they will tell you the same thing I have if you choose to use a beta :rolleyes:
I will be installing the Biostar today, as my 780i is finally gone!!! :clap: Being the second Intel board I will have messed around on in a while, I think I will wait for a tested bios rather than cause more problems than I may already cuase myself. :D
On behalf of the others posting here about a "beta" nios, please do not use it if you do not want. You will rag on KET now, and once his finished bios is done, you will use it and not say thank you!
So I advise, if you do not like what is going on in this thread, just ignore it, use the bios when its done, or do not. Either way those in this thread are here because we want to be, not because KET hypnotized us into thinking we could magically overclock our CPUs to 6GHZ on air with his bios. We all know enthusiast products get released before the best drivers/bioses are released and then they get worked on.
That is what is happening here, the bios is being worked on. :up:
yeah biostar has done nothing, I've emailed them over and over and every response is well if you dont like it, sell it. so at least ket is trying. I dont see any of you trying any improvements. on a further update, I FINALLY got may ram to get into windows at 1150mhz prollumn is now they perform at a lower level than at 1066mhz! WTF!!!
yipieh board boot with 1:1 550fsb, i changed the mch gtl to 59 and now it runs? is it normal?
Thats exactly what Im doing. I really cant stand this board. I cant stand Biostar even more. I emailed their US costumer service. They gave me a one sentence responce basicly saying "email our Tiawan department". I did that a few days ago and still no responce. I overpayed for a budget board with no software support. There has not been a new bios releace in 3 months, not so much as a beta. There is NO help coming from Biostar. Ket is your only chance. He is doing what we PAYED Biostar to do. Thanks for listening to my rant.
