Originally Posted by
jason4207
I've always heard 20x, but it doesn't need to be super accurate anyway.
I was speaking specific to this thread, and the stock reading on the PCB is ~5k, so most folks are using 100k VR's. The poster said he was using a 25k VR, and thought a 10k VR would work better...I disagree.
About my dead GT...It was my first time mounting on to a naked die. After the card popped while running FUR I took it out and dissected it. The first thing I noticed is that the PCB was bent from the excessive pressure I used while tightening the nuts. Then while loosening the nuts I noticed that the bracket wasn't all the way snapped in on 1 corner. When I wiped the core clean I noticed one corner looked chipped off slightly.
My conclusion was that the heat coupled w/ the uneven pressure caused disaster. It was probably a lot more due to the uneven pressure since temps were still in the 60's, but I have to assume the heat didn't help b/c it was fine up until that point.
