Originally Posted by
Oginger1
Thnks for the responce deathspine. My entire system is waercooled. (CPU, Motherboard and graphics.) In the last 3 months I've tried just about every variation of the BIOS settings, I've been slowly upping the voltages on CPU, NB, SB, VVT and PLL till well byond recommend levels and still it wont run stable. Suprisingly the settings I posted above are the most stable I've found, and the one I revert back to when all others fail. With these setting it will pass Intel Burn test but fail Prime95 blend or large (it will run small)
To be honest I've had about as much hassle as I will take from this board. On friday it's back to the shop and as long as there's no problems I'll be giving this back to them and going either XFX or EVGA. They seem to be much better boards running stable with no problems. Unless I can sort this board before then, well it's bye bye Asus.
