Evil....
I've heard of a few people with some complaints about this case and I wanted to know if any of them are valid.
1) "The side panel is flimsy and is not brushed aluminum like the rest of the case is"
2) "The side panel never fits on correctly... same thing with the motherboard tray. The screws never line up properly"
3) "The hard drive mounting system makes it so that the hard drives are not mounted straight because when you turn the screws, it moves them"
Also, how do you recommend stealthing a DVD Drive to perfectly match this case?
