Originally Posted by
Aivas47a
Sorry about the small pics guys. :am: I'll try to edit and replace with bigger pics after work.
Basically what the pics show is much slower default memory read/write (like several thousand points) and higher latency on the 790 vs. the X48. Cache performance numbers are almost the same.
The numbers for both boards are strictly using default/auto memory settings except for manually setting 1800 and 8-7-7-20 on the main timings.
Everest performance for both boards can be improved a lot with tweaking, I just found it interesting that the "plug and play," default performance of the boards would show such a big difference.
The difference in memory bandwidth numbers does NOT translate into any noticeable difference in super pi (the 790 actually has the better 1M time) or 3DMark06 (results using same video card are not in my post but are almost identical).
dinos/others, forgive my ignorance but what is the P1/P2 setting and how should that be tweaked?
