Wow, I got my friend a set of those and a set of the tracers for myself :)
Do you guys all use active cooling on the chips? I can get it stable @ 600 5-5-5-15 with 2.2v on my p5k Deluxe...
The ballistix are damn hot! Will active cooling (3 x 50mm fan) result in a little wonder for me? :P
It wont hurt thats for sure. I never use me system without cooling for mem.
The ram might be over volting a bit btw ;) Get a dmm and check it out :) But AMAZING :D
Ballistix 8500 for $139 at PGN
http://www.priceguidenetwork.com/com...864aa1065.html
:up:
Seems i got luck, second kit i buy, second kit that does the same :D
DDR2-1200 5-5-5-15 2,1v 100% Memtest stable
http://img182.imageshack.us/img182/1554/247gp8.th.jpg
Awesome results BTW caesarean :up: I will try with less vdimm this weekend :)
not 100% stable (memtest windows & only 101% coverage)
test with memtest86 8hours :D
my ballistix PC8500
2.2V 660 MHz 5-6-6-18
http://valid.x86-secret.com/show_oc.php?id=218639
2.15V 560 MHz 4-4-4-4
http://valid.x86-secret.com/show_oc.php?id=218648
1.9V 594 MHz 5-6-6-18
http://valid.x86-secret.com/show_oc.php?id=218652
:D
Finally finished testing all pairs on Asus P5K Deluxe 0311 bios. I can now say all pairs are pre-tested and validated :D
6x pairs of 2x1GB Crucial Ballistix PC2-8500 (3 tracer sets + 3 non-tracer sets)
Results are as follows:
Crucial Ballistix non-tracers PC2-8500
- Each pair non-tracers are more consistent in overclocking than the tracers pairs.
- Didn't standardize the 4-4-4-x tests with the non-tracer pairs until later into my testing with 5-5-5-15 and subsequent Ballistix Tracers arriving.
Pair #1 & #2 & #3 (heatsink spreaders intact)
- 2.20v = 510mhz 4-4-4-9 2-25-2-2-4 (very tight subtimings need more vdimm)
- 2.45v = 551-561mhz 4-4-4-12 3-30-3-3-8
- 2.45v = 600mhz 5-4-4-9 3-25-3-3-6
- 2.10v = 621mhz 5-5-5-15 3-30-3-3-8
- 2.15v = 625mhz 5-5-5-15 3-30-3-3-8
- 2.20v = 630mhz 5-5-5-15 3-30-3-3-8
- 2.25v = 635mhz 5-5-5-15 3-30-3-3-8
- 2.30v = 640mhz 5-5-5-15 3-30-3-3-8
- 2.35v = 645mhz 5-5-5-15 3-30-3-3-8
- 2.475v = 651mhz 5-5-5-15 3-30-3-3-8
Crucial Ballistix Tracer PC2-8500
- Pair #3 best 4-4-4-12 oc'ing followed by Pair #1 and then #2
- Pair #3 best 5-5-5-15 oc'ing requiring lower vdimm than pair #1 & #2 of Tracers
Pair #1 (heatsink spreaders intact)
- 2.10v = 500mhz 4-4-4-12 3-30-3-3-8
- 2.20v = 533mhz 4-4-4-12 3-30-3-3-8
- 2.25v = 540mhz 4-4-4-12 3-30-3-3-8
- 2.30v = 550mhz 4-4-4-12 3-30-3-3-8
- 2.35v = 561mhz 4-4-4-12 3-30-3-3-8
- 2.40v = 570mhz 4-4-4-12 3-30-3-3-8
- 2.45v = 651mhz 5-5-5-15 3-30-3-3-8
Pair #2 (naked Micron D9GMH ICs no heatspreaders)
- 2.25v = 534mhz 4-4-4-12 3-30-3-3-8
- 2.30v = 551mhz 4-4-4-12 3-30-3-3-8
- 2.40v = 561mhz 4-4-4-12 3-30-3-3-8
- 2.45v = 570mhz 4-4-4-12 3-30-3-3-8
- 2.10v = 625mhz 5-5-5-15 3-30-3-3-8
- 2.15v = 630mhz 5-5-5-15 3-30-3-3-8
- 2.20v = 635mhz 5-5-5-15 3-30-3-3-8
Pair #3 (heatsink spreaders intact)
- 2.20v = 534mhz 4-4-4-12 3-30-3-3-8
- 2.45v = 576mhz 4-4-4-12 3-30-3-3-8
- 2.10v = 635mhz 5-5-5-15 3-30-3-3-8
- 2.15v = 640mhz 5-5-5-15 3-30-3-3-8
- 2.20v = 645mhz 5-5-5-15 3-30-3-3-8
- 2.30v = 651mhz 5-5-5-15 3-30-3-3-8
- 2.40v = 661mhz 5-5-5-15 3-30-3-3-8
Seems overall, the Crucial Ballistix Tracer PC2-8500 have a 10-20mhz higher 4-4-4-12 overclock then non-Tracer pairs and slight better upper max 5-5-5-15 or lower vdimm requirements as non-Tracers.
i just got a set of tracer 8500s.
so far 500mhz 4-4-4-10 2.25V (2.26V measured with fluke multimeter).
does not run same speed/timing at 2.15.
p5b deluxe, vdroop modded. 3.6 ghz, 400fsbx9.
going to try for higher speed tonight. maybe 600 4-4-4-10 is possible with 2.4V.
good news!!
2.45v, 400mhz, 3-3-3-8 is orthos stable
0.005V droop measured by multimeter.
will update on 600 mhz.
aiming for 5-5-5-15 600 mhz, lowest volts.
BallistiX PC8500 2.2V 602 MHz 5-5-5-10 SPI32M stable
http://www.enregistrersous.com/image...0721032209.jpg
:up:
Some suicide screens with 2.60 vdimm:
http://img.photobucket.com/albums/v2...-152.60v1M.jpg
http://img.photobucket.com/albums/v292/Viss1/720val.jpg
the ballistix has died ? (loc.o) ?
and :up:
Orthos, Vdimm 2.04V ( 2.025V bios set ), 0424
Can u share your bios settings?
i cant pull off 600 5-5-5-15 2.25v orthos stable for over 20 minutes. 400 3-3-3-8 is ok at 2.4 orthos stable.
gotta reinstall my os for superpi.
Sweet testing Eva2000 :)
Just a quick test I did a few weeks ago using only 2.0Vdimm set in bios for 600MHz for my PC8500 Tracers :up:
http://img150.imageshack.us/img150/508/600mhzhb7.jpg
My kit of these came in the other day. Unfortunately, without a processor I can't test them! It's killing me!
