DI + 2v + 3'C stress :D
hehe... 2v, not on this chip ;)
@ ~+3°C the coldbug hit my face :(
what htt for 3° ?
~328mhz
Do u need good RAM ? :D
damm this thing kicks butt! NICE WORK!
this weekend i'll go for sub 20min SuperPi 32M.... may be i try 1M once again, with more voltage...
WR UPDATE
superpi:
http://octs.ripping.org/3700_wr/22.750_xs.jpg
pifast:
http://octs.ripping.org/3700_wr/33.23_xs.jpg
superpi 32m: 3700+ @ 3604mhz / 2x256mb bh-5 258mhz 2-2-2-5
http://octs.ripping.org/3700_wr/superpi_32m.jpg
sub 20min on 32m is defenetly not possible... i tried 32m only once... i think the time could be a few seconds better...
Erm... that Pifast has ***error in computation*** so unfortunately it's not valid.
For that 32M run, sub 21 minutes ought to be a walk in the park at that speed, i get 22 min 10 sec at only 3220MHz, time to break out some tweaks.
Good luck and nice speeds! :up:
ou... i saw it too late... here is a valid pifast-screen... but pifast suxx...
http://bastel-gianni.ripping.org/ove...fast_33.70.jpg
Use win 2k3 and your sub20 already.Quote:
Originally Posted by gianni-gt
ok... then i'll install 2k3...
You think win 2K3 is gonna shave off 1 min 22sec?Quote:
Originally Posted by massman
Nah, not a chance mate.
Just search around on this forum, in the Xtreme SuperPi section used to be a thread called SuperPi tweaks.
Just go there and have a read.
Like i said, sub 21 min sould be a piece of cake. ;)
Sure, even more than 1m22.Quote:
Originally Posted by Zeus
I would like to give you some examples, but my I can't acces my results hdd for now. I had about more than 2m gain with 150MHz. less ;).
http://i3.photobucket.com/albums/y72...m/66b34630.jpg
I though i was miles off the pace with 3.4ghz, i had it upto 3.6ghz suicide shot.
Looks like i'll have to dust off the old chilly1
Tom
2k3 installed, 32m is running, with the same settings as under winxp...
Sweet, in a few minutes I'm expecting results :D
damned atm 32m isn't stable.... i'll try when my fridge-chiller is cold enough...
Insane. Great job!:clap:
ok guys, i reached the max with 32m! but sub 20min is absolutly not possible! windows 2k3 and my fridge-chiller@-28°C, more than 30sec better than before = not bad
http://octs.ripping.org/3700_wr/supe....859sec_xs.jpg
Awesome job dude, gl for this project, so much xtreme!
Awesome speed bro. :toast:Quote:
Massman, not sub 20 minutes :slapass: :D what did he do wrong?
TBH i think you (Massman) either had a very bad XP or a very good setup 2K3.
Let me do some calculation:
I scored 22 min 10 sec at 3230MHz (see sig), for every added 10MHz i took of about 3~4 seconds.
You have 400MHz more which means 40x3=120 seconds= 2 full minutes.
22 min 10 - 2 min = 20 min 10 sec. :fact:
Since i took 3 second for 10 MHz one should expect to shave of even a bit more.
With a very well tweaked OS sub 20 minutes should be doable.
I suggest you'd have a read here:
http://www.xtremesystems.org/forums/...ad.php?t=49345
Tweak that OS to the max and show us sub 20 minutes. :toast:
i've read this thread already ;)
i think the problem is my ram... my 2x512mb kit is much faster but not stable @ 32m at these clocks :(
I used some OPB tricks (nothing special, just keeping your system clean). My XP setup wasn't that great (24/7), but it was quite clean.Quote:
Just make sure your server03 installation is very clean ;)
last benchmark for a while:
http://octs.ripping.org/3700_wr/33.28_xs.jpg
next weekend the FX-55 with WR-Stepping is comming... and another 3700+ as well ;)
