Rauk - what clockgen do you use?
My Core 2 Duo is stable at 1.2750 V at 8*401 Fsb .... Same stuff as above almost
1.2?!?! Did you run prime and superpi?
Version 1.0.4.8Quote:
Originally Posted by Avman
Clock Generator Setup PLL Selection CY28551
My results so far with my L626A289 -
http://img150.imageshack.us/img150/345/primeva5.jpg
nice clock you have. I can bearly make it stable to run 3.6Ghz at 1.6v in bios.
Here is mine @3.2. Will post update if i can make it 3.6Ghz stable overnight
Processor: E6400 @ 3.2Ghz (week 26)
Motherboard: P5B Deluxe Wifi
Memory: XMS2-8500 3-4-4-8 @800Mhz
FSB: 400
Memory Mult: 1:1
vcore: 1.4 vdimm: 2.4
The rest all set normal voltage (first in the list)
Ambient 29-30
Idle 46 degree
Load 58 degree
Stable on Orthos for 8hrs
Orthos Stable 30 hours ... but if I turn off the LCD monitor, when I turn it back on ... nothing works... however, i can still shutdown windows, and hear the shutdown sound .... XD
Haha, that used to happen to me w/ a DFI nF4 SLI board.
My best 1M so far, but forgot to set CL to 3, will go for some better scores tomorrow. :)
http://img85.imageshack.us/img85/3536/14969lk0.jpg
Vcore is 1,544V.
http://img223.imageshack.us/img223/1...erpi300qx0.jpg
I use that boxed cooler, so my CPU is running pretty hot. Also Southbridge is pretty hot. Easytune says that my CPU use 1.41 Voltage, thats too much. I dont think that I should overclock any more with boxed cooler, so I'm getting Scythe Ninja.
Change manually in your BIOS to 1.3-1.35V and try some more OC.Quote:
Originally Posted by ClockCatcher
Thanks for the tip, that reduced my temps about 10C.Quote:
Originally Posted by mach82
Also I'm thinkin which temps should I look, CoreTemp or BIOS/SpeedFan/Easytune? CoreTemp shows about 10C more than other.
CoreTemp! EasyTune/DS3 sensors are total crap. ;)
Should I go lower than 1.3V, Im trying to get lower temps.
Sure as long as you can run some apps without the pc locking up. for exaple Orthos,etc...Quote:
Processor: E6400 @ 3.7Ghz (week 27)
Motherboard: P5B Vanilla
Memory: Teamgroup PC5300 3-4-4-8
FSB: 463
Memory Mult: 1:1
vcore: 1.5 vdimm: 2.2
http://aycu09.webshots.com/image/292...3983484_rs.jpg
rgards
Nice one, Mascaras! You've ditched the DQ6, I see.
CPU-E6400@ 3700 MHz+BOX COOLER
MB:Gigabyte 965P-DS3 F6 Bios
RAM:SuperT 800 MHz 3-4-3-8,OC@ 5-5-5-20
Mem Multi: 1,1
Vcore:1,525 Vdimm:2,1
Your CPU must be cookin' ;) What temps are you getting with the boxed cooler and that OC?Quote:
Originally Posted by Fixt00l
53C in BIOS,full load goes 76C-78C:eek: :rolleyes: :stick:Quote:
Originally Posted by GAM
E6400 3.6GHz 1.408Vc air
E6400 L625A 3.6GHz 1.408Vcore
Scythe Infinity
Gigabyte DQ6
2048MB CellShock DDR800 :D
Only priority 7 since i was doning some work while prime was running. will test priority 10 later.
raiden
http://img151.imageshack.us/img151/6730/38523gx5.th.gif
Processor: E6400 @ 3.85Ghz (week 24)
Motherboard: Gigabyte P965-DS3 with bios F3
Memory: XMS2-6400C5 @ 5-5-5-10 2.1V
FSB: 482
Memory Mult: 1:1
vcore: 1.6V
vdimm: 2.1V
yep :DQuote:
and its settings booting from bios , cause there is no SETFSB for P5B Vanilla yet .
with SETFSB and better RAM i think 3.9ghz can be done ;)
This CPU seems to have a lot of potential :
Temps@CoreTemp @ WC
http://img242.imageshack.us/img242/1...swq9rx2.th.jpg
with vcore default runs SPI 1M at 3352mhz :
http://aycu09.webshots.com/image/472...4935307_th.jpg
3300mhz@1.328v @ Orthos
http://aycu37.webshots.com/image/547...4599717_th.jpg
3570mhz@ 1.425v :D
http://img520.imageshack.us/img520/2...143vbc4.th.jpg
3615mhz @ 1.45v
http://img257.imageshack.us/img257/5...146vnv4.th.jpg
3700mhz@1.50v (booting from bios)
http://img178.imageshack.us/img178/4...0spivz2.th.jpg
lets wait , I hope that a SetFSB for P5B come out ;)
regards
Lets hope my E6400 will do better then my E6300 (7*500@1.4V).
