CPU Model: E6600
CPU Clockspeed: 3.ghz
CPU Voltage: 1.3v
Motherboard: Asus P5W DH
BIOS Version: 1101
Heatsink/Block: Freezer Pro 7
Fan: freezer pro on optimal (1000rpm)
Idle/Load: 48-50 / 60-60
Ambient: 42
Utility Reading Temps: Everest / Coretemp.
CPU Model: E6600
CPU Voltage: 1.3v
BIOS Version: 1101
Ambient: 42
What Operating System are these idle temps taken from? My sytem idles 12C , Hotter in Windows 2000 Pro SP4 than XP Pro SP2.Quote:
Originally Posted by o_neill_dude
Your idle temps are much like mine, can I ask you what Operating system you run? My Windows 2000 Pro SP4 runs about 12C warmer than XP Pro SP2.Quote:
Originally Posted by Jimbo
I attribute that to lack of speedstep drivers in Windows 2000.
They are built into XP. In the past was the manufacturers responsibilty to supply the drivers with the motherboard.
CPU Model: E6600 Retail
CPU Clockspeed: 2.4GHz
CPU Voltage: 1.2v
Motherboard: Asus P5B Dlx
BIOS Version: 0614
Heatsink/Block: Intel Retail
Fan: Intel Retail
Idle/Load: 48c/60c
Ambient: 24.4c
Utility Reading Temps: Core Temp
Case: P180 1 tricool exhause, 1 panaflow 85cfm exhaust, 1 panaflow 85cfm intake, 1 tricool intake
OS: WinXPSP2
I'm waiting on a Big Typhoon to replace the stock cooler. So I'll repost when I get the BT, stock, and OCed temps.
Those lists of temps/fans/heatsinks is nice, but you guys should also list the computer case you have, and the number of fans blowing air into them :)
Also don't forget to post which Operating system you use.Quote:
Originally Posted by itznfb
One of the key differences in Windows 2000 and XP is that XP has speedstep drivers built in. A motherboard with a speedstep enabled E6600 can idle at a cool 1.6GHZ while a E6600 on the Badaxe has to grind away at 2.4GHZ all the time.
I know I'm harping, but no one is posting their OS info... :(
i edited my post.
CPU Model: X6800 Retail
CPU Clockspeed: 3.47Ghz OC'd
CPU Voltage: 1.385v in CPU-Z
Motherboard: Asus P5W DH Deluxe
BIOS Version: 1201
Heatsink/Block: ThermalRight SI-128
Fan: Panaflo L1 @ 1600 RPM
Idle/Load: 32c/57c for the two cores
Ambient: ~23c
Case: Stacker 830, 1 Exchaust fan, 2 HD cages each one has fan for each drive that i have. Two Side panel Fans(Panaflo M1's running at max RPM)
OS: Win-XP-SP2
The 2 drives i have are running at a cool 26c if anyone likes to monitor those temps.
CPU Model: E6600 OEM Stepping 6 Rev B2
CPU Voltage: 1.3V
BIOS Version: 0801
Heatsink/Block: Swiftech Storm
Fan: N/A
Idle/Load: 33°C,23°C / 41°C,31°C
Ambient: 22°C
Utility Reading Temps: Core Temp, Everest (same readings as SpeedFan)
Case: Lian-Li PC-75B with 2x80mm front and rear (stock) and 2x120mm fans pulling air through the rad into the case (mounted in the top).
OS: WinXPSP2
I haven't had the time to start a serious attempt at overclocking yet.
So your getting almost the same cooling with air that I get with water! How quite is it?Quote:
Originally Posted by Peter949
You mentioned you had trouble engaging one of the retaining points, didn't you? Make sure all four points are fully home or you will not achieve good contact between the CPU and heatsink/block and the result will be significantly higher temps.Quote:
Originally Posted by RDTS
I am guessing things still are not seated correctly. Your temps 'should' be lower than air, even the BT.
I am running Windows XP home edition with SP2. I have Speedstep disabled in the bios, because im overclocking, would I be able to use this?Quote:
Originally Posted by GWillakers
CPU Model: E6600
CPU Voltage: default
Motherboard: MSI 975x PowerUp
BIOS Version: 7.1
Heatsink/Block: Big Typhoon
Fan: 1300rpm
Idle/Load: 40-42 / 48-50
Ambient: 28
Utility Reading Temps: Dual Core Center
Thanks for your assistance,Quote:
I believe speedstep has to be disabled both in bios and the OS.
One way to interogate, is to right click my computer, bring up the properties page, general tab... you should see a label something like E6600 2.4 GHz, under that it would say 1.6GHz if speedstep is active.
{of course you wouldn't run heavy tasks while doing the above}
CPU Clockspeed: 2.4GHz (all settings stock)
BIOS Version: 0701
Heatsink/Block: Thermalright Si-128
Fan: Scythe 1200rpm
Idle/Load: 52c/66c
Ambient: 26c
Case: Coolermaster Stacker 830, stock fans (one in front for HDs, one in back)
OS: WinXPSP2
There is obviously something really wrong with my temps. What is interesting is Asus PC Probe II says the CPU is 33-34c idle, 48-50c load. That is a lot bigger gap in tempature than I see in a lot of these posts. The Si-128 is a real pain to get seated correctly, but I have the thing on there right now so tight it is bending my MB a pretty good amount. Unfortunately, I think my chip is not flat because when I was trying to get the Si-128 on, I was noticing the thermal paste was not touching the heatsink in the center, only on the sides. I don't really know what to do about that, I am not going to lap it or anything of that nature. I was hoping to overclock this thing to atleast 3ghz, but as of now it seems as though it is too hot even at stock speeds. I wonder if I should buy something easier to put on. The only thing I am worried about is getting a heatsink that will fit in my case with the fan tray on the side.
You MUST have good contact or your temps are going to sky rocket, particularly under load.Quote:
Originally Posted by perfektrtw
If things aren't flat and you don't want to make them flat, you need more thermal paste. Place a 'little' more than you used originally on the centre of the CPU and then carefully press down evenly using the block's retaining method, which should squeeze out the paste evenly and fill the void between.
Sounds like you're overtightening to compensate. This won't work. You won't force the mating surfaces flat by doing this. Try not to bend the motherboard (easily said, I know ;) )
CPU Model: E6600
CPU Clockspeed: 3.00ghz
CPU Voltage: 1.35v (BIOS), ~1.33v idle (CPU-Z), ~1.32v load (CPU-Z)
Motherboard: P5W-DH Deluxe
BIOS Version: 1301
Heatsink/Block: Stocker... what a piece...
Fan: Stocker
Idle/Load: 28/46*C
Ambient: 20*C (estimated)
Utility Reading Temps: SpeedFan 4.29
IHS: Unmodified, slightly concave when compared to a credit card
CPU Model: E6600
CPU Clockspeed: 2.4ghz
Motherboard: Intel D975XBX
BIOS Version: 1304
Heatsink/Block: Scythe Infinity
Fan: Scythe 120mm @ 1200rpm
Idle/Load: 35 / 45
Ambient: 28
Utility Reading Temps: Coretemp
OS: XP Home SP2
Case: Silverstone TJ-06
Case Fans: 1x Silverstone 120mm @1200rpm (Front), 1x Yate Loon 120mm @ 740rpm (Rear), 1x Silverstone 80mm (Front)
IHS & Heatsink/block NOT lapped
CPU Model: E6600 Retail Stepping 6
CPU Clockspeed: 3.42GHz / 380Mhz FSB
CPU Voltage: 1.500V (Bios)
Motherboard: Gigabyte 965P DS4
BIOS Version: F3
Heatsink/Block: Zalman CNPS9500 LED
Idle/Load: 54°C / 74°C
Ambient: 20-something °C
Case: Lian-Li 6070a with 120mm front and 250mm fan in the door sucking in air.
OS: WinXPSP2
IHS and heatsink is lapped. Still damn hot, but stable...
What are the max safe temps for E6600 and due to which temp readings (Core Temp or something else)?????
got the big typhoon installed.
initially dropped my temps quite a bit.
31c/42c on stock volts.
as soon as i bumped up the volts to 1.45 though temps went up to 45c/62c. so i think i may have a bad mount. i'll have to try again tonight.
New wc sistem on my E6400 :D
http://img359.imageshack.us/img359/5...sbaixaszx6.jpg
regards
it sure does ! :)Quote:
I've just been looking through and comparing some of my historical Everest logs and notice that Core #1 is consistently 2c hotter than Core #2, pretty much running F@H constantly on both cores 24/7 for weeks.
Anyone else notice this?
I read somewhere that there aren't two physical cores on a C2D as such, however, could this imply that I have an eneven spread of Artic Silver 5 (thermal interface material)?
Originally Posted by GAM
my cores are usualy 2c off in tat and core temp, the strange thing now is that tat is showing 4c difference between them :)
on the side note, ppl that are posting thir temps should post with what software for load
