:eek:
Well done Tam the memory bench on its own is world record class...:D then 1st over 5000mhz.....:D and proberbly tonight 9.9x .:cool:
:eek:
few month ago the first fx at 4 gh was a milestone.... here we are before the real launch of the product : 1ghz more with two cores and a 30% faster chip
it never happen in ocing world: we are in the future!
great job tam
Its been a half year+ as far as I remember, but yes amazing :)Quote:
Originally Posted by titouille
04-07-2005, 03:49 AM, quite a while ago...
a day we all are going to remember is when the 10ghz limit brakes!
its so close to 9.xxx S now! :)
Wow!
Only 0,140" for broke the 10" barrier!:eek:
Incredible!:toast:
nice done bro... nice done !! perfect !!
I want to see single digits :banana::banana::banana::banana:
C'mon TAM, you can have your vacation once you reach 9.xx sek. Where is my 9 seconds.. c'mon. Once you reach it, we can call it a day and we all happy and go home.
I'll be satisfied if mine will do 12s on H2O :toast:
Be sure you monitor the temps on water. GL.Quote:
Originally Posted by CompGeek
What is the max I should allow for?
hmmm.... I don't know, -30C probably?Quote:
you may not need it get it that cold with the better stepping of the core which will let you overclock to get the numbers you want.
CPUz only 5MHZ higher as Pi1m - if it was max CPUz then the 1m is really almost maxed out...amazing work but seems harder and harder this 9s wall.
Hey, simply amazing score! Not only for the 5GHz+ but the mem. too! I have a tweak for you to make: Idle Cycle Limit. Drop this down to around 8. You will see a massive difference in SuperPi. ;)
I REALLY want to see 9.xxx , however amazing job so far coolaler ! :clap:
It is astonishing: D
lol, umm, im on water. I just mean before im risking chip damage.Quote:
Originally Posted by IamAnoobieCheez
It will be hard to get past 3.4-5ghz on water with 6600Quote:
Update By TAM
A slightly improved modPI 1M 10.140s @5013.1Mhz this weekend.
I like the ATI RageXL.. I bet this rig would give highest RageXL 3DMark2001 ever!Quote:
Time: 10.140s (Super PI / mod1.4)
Clock: 5013.1MHz (fsb417.8MHz x12)
CPU: Core 2 Extreme X6800 : (2.93G/266x11/FSB 1066/L2 4MB)
M/B: Intel D975XBXLKR-rev302 modded (bios:1073)
CPU Cooling: LN2 (Pro4 + V-TEC ARC Bed Rev.3.4)
Memory: Corsair PC2-5400UL(v1.3) 512MB x2
VGA: ATI rageXL (PCI)
HDD: IBM DTLA-307020
Power Supply:Zippy-460w
Vcore: 1.74v, Vdimm: 2.55v, Vio: 3.65V
OS: Windows Server 2003
MEM: 4:5, CL4-3-3-2
10.14s in SuperPI 1M June 2006.
I would have never imagined.
Just a few years ago, folks with their shiny new P4 and i865 were gladto break 50s. If back then you announced <20s SuperPi with <3Ghz INTEL processor, you'd be dismissed as a raving lunatic (nevermind 10s and 5Ghz on 14 pipeline architecture). Conroe performance is absolutely revolutionary.. true next generation performance.. like comparing a 486 to a Pentium.
I think Intel's decision to abandon Pentium brand name and start new series is well deserved as they open new chapter an d put that netburst Prescott mess behind them.
EDIT: TAM, omedeto gozaimasu!
Kimi ga Chou Kakkoi Da
wow amazing
Yeah, it's nearly done. :fact:
Just 2 tens of a sec. and we have 9.xx :slobber: :woot:
I keep checking back on this thread atleast 1-2 times a day to see if the 9.xx has been broken, it has to be happening any day now, sooo very close.
so far the record is 10.14s with 5013Mhz right?
10.14/9.99 ~ 1.0150
1.015x5013 = 5088Mhz
right now at 417.8 fsb, and would need 424 fsb.
although its *only* 1.5% more, he's already at a totally crazy speed of over 5Ghz!
Inccidentally, does larger L2 cache help in SuperPi? Current Conroe has 4 MB which is half of the ~ 8 MB of memory allocated for 1M run. What do you suppose would happen if he had a Conroe with 8 MB L2?
burn him :yepp:Quote:
Originally Posted by ***Deimos***
great job
