sweet CPU Stephen :)
Is it the 290fsb chip stephen?
Yes it is....we'll see soon if it can reach that speed....someone really needs to come up with a Vcore mod that allows for higher than 1.64V. This cpu seems to be more limited now by vcore as opposed to FSB.....Quote:
Originally Posted by NiCKE^
How much do you need? 5v? :P
LOL...1.7 - 1.8 would be nice :DQuote:
I'll look for the explosion from here:rofl::explode2:
joint the dark side there ? :)
Other way around, he came where the light is ;)
Ok, tested the cpu last night on my autocascade and I've learned something new.....-80C insulation doesn't work too well @ -100C temps :p: I'll have to do some more insulation before trying again since the board is acting up. FWIW, I reached 295x13 for a short bit before the board locked up and didn't want to boot again :rolleyes: ~-103C IDLE temps, -102C LOADED :cool:
I thought your Auto was running -150° now or something? Hurry up and insulate that rig properly ;)
Those temps were for for fun ;) (It actually made it down to -162C). With a decent capacity, the numbers will have to be quite different. The temps I reported in my last post are from an probe in the cold plate on top of the core. Actual evap temps should be ~-115C....Quote:
Originally Posted by G H Z
Nice CPU mate :)
Now get rid of that autocascade and get some LN2 for the sucker ;) - 4ghz yonah action, common :D
EDIT: GAH I need a new mobo, but this freakin' contry still havnt got them, GHZ's past me in 01SE - last time I looked I was LAST on front page, now this sucks :(
No need....I think I can do 4ghz with the auto ;)Quote:
Originally Posted by M.Beier
AYE CARAMBA :DQuote:
Originally Posted by s7e9h3n
... Just dont touch 01SE dude!! :slapass:
Oh...just remembered.....I wasn't @ -100+C when I saw teh 295FSB...I forgot had actually turned the cooling head off. IIRC, temps on the cold plate were ~-48C :DQuote:
You can buy one here http://www3.atelco.de/8AvRLj_yBr9-Mw...aid=6636&lid=2Quote:
The shipping charges for Denmark are 17,50€ http://www2.atelco.de/7AewJFNvVOjsRx...oagbprivat.jsp
Or here http://www2.hardwareversand.de/7VXqw...aid=6636&lid=2
Update
By fredyama(PRTeamJapan)
M/B: AOpen i975Xa-YDG#2 Mods by duck;)
Cooling: LN2
modPI 1.5 XS 1M: 15.984s @3733.7MHz (FSB287.2MHz x 13)
http://green.ap.teacup.com/fredyama/img/1148632047.gif
modPI 1.5 XS 8M: 3m01.953s @3733.5MHz (FSB287.2MHz x 13)
http://green.ap.teacup.com/fredyama/img/1148632487.gif
modPI 1.5 XS 32M: 14m20.000s @3719.2MHz (FSB286.1MHz x 13)
http://green.ap.teacup.com/fredyama/img/1148632698.gif
http://home.arcor.de/jodee2/suerpiYo...entonFATD9.JPG
T2600ES 8
AOpen i975Xa-YDG (vdimm mod)
4x512 MB Centon Advanced @ 2,3 V
Vapochill LS
1,5V
Last night, I found that I didn't have any more Ceramique left so I ended up running the yonah without re-insulating the board as I had originally planned - BAD IDEA :p: I ended up spending the entire night pulling my hair out trying to figure out wtf was causing the cpu to act so erratic. I messed with timings, voltages, memory slots, etc. - everything I could think of but I was only able to manage a few completed Spi runs @ NOWHERE near the cpu's top speed :rolleyes: :
Evap temps @ ~-115C IDLE, ~-114C LOAD
http://img397.imageshack.us/img397/4...8x131ma9ao.jpg
http://img397.imageshack.us/img397/7946/278x138m5hw.jpg
These runs were basically done a couple of minutes before I shut down for the night. As I reached around the autocascade to turn the unit off, I noticed what had been causing my frustration for the last couple of days :rolleyes: .....
http://img225.imageshack.us/img225/795/leak0ex.jpg
This wasn't just a thin layer of frost -> rather it was a SOLID chunk of ICE that took ~5 minutes to melt with a hair-dryer on the "HIGH HEAT" setting :wth:. Luckily the hardware seems to be in good condition still, so hopefully I'll be able to get in a few nice runs sometime this weekend. The cpu's got quite a bit more left in her - this was done earlier in the night, most likely when that iceberg was still in it's infancy :p:
http://img147.imageshack.us/img147/5...13valid4ff.jpg
4ghz is within reach :cool:
300FSB!!
Congrats :clap:
Amazing stuff Stephen. I got an "iceberg" as well in exactly the same spot... I don't think it caused me any trouble since I sorta always ran with some ice in various spots.
Now, isn't it nice to move to a platform where lower temps get you a higher FSB rather than a lower one? (HTT) ;)
LOL...this wasn't any ordinary iceberg, this one could have sunk the Titanic as well :p: . Stuck a hair -dryer on it and it basically didn't start melting for a good 2-3 minutes. I have a feeling it was wreaking havoc on my Vcore as it was all over the place (even for the Aopen). Also, I have a feeling it had something to do with my problems with the setup on my last boot attempt. Basically, I opened up clockgen and tried to set the FSB. Well, somehow the cpu clocked DOWNWARDS and was stuck @ 1700Mhz no matter what I did. I tried the Aopen OC utility but the FSB wouldn't budge and upon re-opening clockgen, ALL the OC buttons were gone :wth: only the "Clocks" button was available.......Quote:
Originally Posted by Gautam
Congratulations !!! :woot:
Stephen, you finally overtook my T2600 WR, 300fsb is a hell of an achievement. The most impressive is to it with a single compressor cooling, where mine needs three to work :D
One more time : :toast:
Well done stephen....keep this toy..i am comming to catch you over there....:D:D:D
Thanks my friend, but this cpu is nothing if it can't run @ these speeds. Yours is a gem, especially considering that you hadn't even done the vcca mod ;) :toast:Quote:
Originally Posted by Tyrou
