looooooooove that cuplex xt. nice pics krueml
Hopper nice case but what are the specs of the watercooling i see a swiftech micro res :)
Germans are perfectionists indeed. Only if they weren't so obsessed with restriction and small tubing... :p:Quote:
Originally Posted by Burn
hopper....you have alot of extra drive bay that are free, go get a better res, thats crap, if u have the money, they only run about 30 for a decent one an get some crome barbs
clean up your case too, it looks nasty
Whats wrong with the swiftech micro? IMO it's one of the best res you can buy.
Actually the swiftech MCRES is one of the better ones, very well designed :)Quote:
Originally Posted by fearilicious
21-24C idle on the e6600 cpu (stock speed)
storm block
BIP rad (possinly upgrading next time)
mcp665 pump
swiftec res
Cooler Master Praetorian modified by performance pc's (window) and me (top grill/paint/led ring power switch)
http://www.performance-pcs.com/catal...oducts_id=2725
p5w digital home/e6600/gskill 800
yate loon(spelling) top fans (orange 120mm)
seasonic s12 600w
next up i get a new gpu
very satisfied
http://img385.imageshack.us/img385/1056/dsc00968gw0.jpg
heres the loop for inspecting
I have a question, I've notice a some of these cases have just as many fans as a case that does not watercool. I thought the general idea is to cut noise down and get better performance. Kinda defeats the purpose of putting a case full of fans and watercooling doesn't it?
Unless they doing just for the "bling" factor im missing something..
You still need some airflow because of RAM, northbridge/southbridge (unless those are watercooled), and other motherboard components. But because this doesn't need as high airflow as when full-blown aircooling you can get away with slower and quieter fans :)Quote:
Originally Posted by markopoleo
Who makes that set up and did it cost a months salary?Quote:
Originally Posted by sladesurfer
markopoleo ...
my new wc rig is quieter, also i need alot less fans to keep my mb cool now that i dont have a hot cpu heatsink right next to the mb heatsink. also you dont need high cfm fans, the yate loon 120mm fans im running are so quiet you cant hear the 2 of those over my gpu fan. through the rad the air entering my case is still cool (useable) and i have a rear and front 80mm's to cool the insides. when i upgrade to quieter 80mm it will probly be nice and quiet.
so ya my setup is just as loud right now as some standard setups but the inside temp is probly alot cooler
also my pump is silent,, get the yl fans and the quiet pump when you build yours and you will be happy
Hi,
Some pics from my old watercooled Setup (actually Air)
http://img241.imageshack.us/img241/1487/3zl2.jpg
http://img376.imageshack.us/img376/9761/neu3gx8.jpg
http://img243.imageshack.us/img243/5127/444bx1.jpg
http://img311.imageshack.us/img311/5086/koxy3at6.png
http://img214.imageshack.us/img214/892/glanz2bj1.jpg
http://img186.imageshack.us/img186/779/koxy1ss8.png
http://img89.imageshack.us/img89/1495/koxybabe3wm6.jpg
My Polished Mips-DFI-Chipsetfreezer
http://img153.imageshack.us/img153/3316/mipsjd2.jpg
The follow things i have polished for a Friend at work
before:
http://img99.imageshack.us/img99/732/beforepimpct5.jpg
http://img428.imageshack.us/img428/4...repimp2il8.jpg
after work:
http://img169.imageshack.us/img169/369/heutezj4.jpg
http://img299.imageshack.us/img299/655/heute6yc0.jpg
http://img299.imageshack.us/img299/1199/heute10zq5.jpg
koxy
:eek: :eek: :banana:
hmm dang those sure are shiny...
hopper some cable management seems to be in order?
i suggest some round IDE cables or switching to SATA drives for your next upgrades.
also cut down tubing from res to pump, i am sure you won't need it to be that long...
and maybe watercool GPU also to maximize silence?
Hey Kox, nice to see you here, too.. :)
WOW :eek: :slobber:
Bling bling :banana: :banana:
Very nice work on the polishing :clap:
nice bling bling you got there, now run it :D
Very nice setup indeed, I like tubing its easier to see how water flows vs having lots of tubes going every which way.
koxy @ ur dfi-board dont you think..
- Better/Stable RAM Slots are both the Orange ones and not the yellow ones.
- dont u think u shud plug in all the power connections on the board?
hd is sata 2 seagate perpendicular the cable is the dvd, but ya i get it cleaned up and add a gpu
CORE 2 DUO E6600
ASUS X1900XT
ASUS P5W DH Deluxe
Cellshock PC2-8000 C4 DDR2-1000 4-4-4-12
Revoltec Chromus II RPS-500V2 500W
600Gb MAXTOR-SATA 2x300Gb/RAID0
Danger Den TDX BrassTop
Danger Den Tyee
Danger Den D5
Danger Den Fillport
Danger Den Deposito Fillport
Black Ice Extreme Rev. 2 Simple
Black Ice Pro Rev. 2 Doble
ClearFlex 12.5-18.75
http://www.design-gfx.net/oc.es/rl070.jpg
http://www.design-gfx.net/oc.es/rl071.jpg
http://www.design-gfx.net/oc.es/rl072.jpg
http://www.design-gfx.net/rl/90.jpg
http://www.design-gfx.net/rl/91.jpg
With EVGA nForce 680i
http://www.design-gfx.net/oc.es/evga05.jpg
http://www.design-gfx.net/oc.es/evga06.jpg
http://www.design-gfx.net/oc.es/evga07.jpg
http://www.design-gfx.net/oc.es/evga08.jpg
http://www.design-gfx.net/oc.es/evga09.jpg
Luz, Good looking Rig! Why do you have some Pics whit your P5B and some whit a 680i Board ?
Looks really nice!
Very nice pics Luz :clap:
From your nickname, im gessing you are Portuguese or Brazilian :)
Keep up the good work :woot:
[]īs m8
