dont forget to flash the backup ;)
wait a few days
there is 20$ mir commin:yepp:
130$ in canada now @ ncix
http://www.ncix.com/products/index.p...kin%20Enhanced
Yup, I will flash the backup...
Again, anyone answer my Cloud o/c question? What options are available to you on the top half? I only have CPU/Mem multi's but nothing else...
sergio the Ripjaws X 2133 8-9-8 are a nice kit and I just got a second set for one of my machines so I will see if it will run 8GB's stable.
some nite bench on my 24/7 settings for chip, this VGA are the best ones i ever hard i didnt even passed 1.1 stock
http://img854.imageshack.us/img854/9541/50053dm11.png
cheers !
Sergio
Touch BIOS Utility B11.0426.1
http://download.gigabyte.us/FileList...touch-bios.exe
http://download.gigabyte.eu/FileList...touch-bios.exe
Supports Z68 boards only...
I guess it will... later.
From one of the .xml files we can see what is capable of:
Code:<?xml version="1.0" ?>
<Image>
</Image>
<Text>
<!-- main page -->
<Txt Num="0">Вч¶}</Txt> <!-- Exit Button -->
<Txt Num="1">»Ў©ъ</Txt> <!-- Help Button -->
<Txt Num="2">Ѕu¤W§у·s</Txt> <!-- Live Update Button -->
<Txt Num="3">Є©Ґ»ёк°T</Txt> <!-- Information Button -->
<Txt Num="4">:banana:«·s¶}ѕч</Txt> <!-- Restart Button -->
<Txt Num="5">¤W¤@:banana:¶</Txt> <!-- Previous Page Button -->
<Txt Num="6">јWґо¶µҐШ</Txt> <!-- Modify Icons Button-->
<Txt Num="7">©з·У</Txt> <!-- Snapshot Button -->
<Txt Num="8">®СЕТ</Txt> <!-- Bookmark Button -->
<Txt Num="9">:banana:є:banana:¶</Txt> <!-- Home Button -->
<Txt Num="10">АWІv/№qАЈ±±Ёо</Txt> <!-- Overclock -->
<Txt Num="11">¶i¶ҐBIOSҐ\Їаі]©w</Txt> <!-- Boot Disk -->
<Txt Num="12">§Ціt¶}ѕч</Txt> <!-- Quick Boost -->
<Txt Num="13">№qёЈ°·±dЄ¬єA</Txt> <!-- PC Status -->
<Txt Num="14">§у·sBIOS</Txt> <!-- @BIOS -->
<Txt Num="15">ѕг¦X¶gГді]©w</Txt> <!-- Integrated Hardware -->
<Txt Num="16">¬Щ№qҐ\Їаі]©w</Txt> <!-- Power Management -->
<Txt Num="17">ёь¤JіМЁО¤Ж№wі]:banana:И</Txt> <!-- Load Optimized Defaults -->
<Txt Num="18">і]©wєЮІzЄМ±KЅX</Txt> <!-- Set Supervisor Password -->
<Txt Num="19">M.I.T. §Y®ЙЄ¬Єp</Txt> <!-- M.I.T. Current Status -->
<Txt Num="20">¶i¶ҐАWІvі]©w</Txt> <!-- Advanced Frequency Settings -->
<Txt Num="21">¶i¶Ґ°OѕРЕйі]©w</Txt> <!-- Advanced Memory Settings -->
<Txt Num="22">¶i¶Ґ№qАЈі]©w</Txt> <!-- Advanced Voltage Settings -->
<Txt Num="23">¦U¦Ў¦UјЛі]©w</Txt> <!-- Miscellaneous Settings -->
<Txt Num="24">BIOS VERSION</Txt> <!-- BIOS VERSION -->
<Txt Num="25">BCLK</Txt> <!-- BCLK -->
<Txt Num="26">CPU ¤єАW</Txt> <!-- CPU Frequency -->
<Txt Num="27">°OѕРЕйАWІv</Txt> <!-- Memory Frequency -->
<Txt Num="28">Total Memory Size</Txt> <!-- Total Memory Size -->
<Txt Num="29">CPU·Е«Ч</Txt> <!-- CPU Temperature -->
<Txt Num="30">Vcore</Txt> <!-- Vcore -->
<Txt Num="31">DRAM №qАЈ</Txt> <!-- DRAM Voltage -->
<Txt Num="32">CPU «¬ё№</Txt> <!-- CPU Name -->
<Txt Num="33">CPUID</Txt> <!-- CPUID -->
<Txt Num="34">§у·sЄ©Ґ»</Txt> <!-- Update Revision -->
<Txt Num="35">Turbo Frequency(MHz)</Txt> <!-- Turbo Frequency(MHz) -->
<Txt Num="36">Non-Turbo Frequency(MHz)</Txt> <!-- Non-Turbo Frequency(MHz) -->
<Txt Num="37">CPU ®Ц¤Я·Е«Ч(ўXC)</Txt> <!-- Core Temperature -->
<Txt Num="38">DIMM Slot(MB)</Txt> <!-- DIMM Slot(MB) -->
<Txt Num="39">¶i¶ҐCPU ®Ц¤ЯҐ\Їаі]©w</Txt> <!-- Advanced CPU Core Features -->
<Txt Num="40">CPU :banana:їАWЅХѕг</Txt> <!-- CPU Clock Ratio -->
<Txt Num="41">CPU °тАW±±Ёо</Txt> <!-- BCLK/DMI/PEG Clock Control -->
<Txt Num="42">CPU °тАWЅХѕг</Txt> <!-- BCLK/DMI/PEG Frequency -->
<Txt Num="43">°OѕРЕй:banana:їАWЅХѕг</Txt> <!-- System Memory Multiplier -->
<Txt Num="44">PWM Frequency Control</Txt> <!-- PWM Frequency Control -->
<Txt Num="45">CPU Over Current Protection</Txt> <!-- CPU Over Current Protection -->
<Txt Num="46">¤єіЎCPU PLL¶W№qАЈ</Txt> <!-- Internal CPU PLL Overvoltage -->
<Txt Num="47">§@·~ЁtІО¤є§Y®ЙЅХѕгCPU:banana:їАW</Txt> <!-- Real-Time Ratio Changes In OS -->
<Txt Num="48">Intel (R) Turbo Boost §ЮіN</Txt> <!-- Intel(R) Turbo Boost Tech -->
<Txt Num="49">Turbo Ratio (1-®Ц¤Я)</Txt> <!-- Turbo Ratio(1-Core) -->
<Txt Num="50">Turbo Ratio (2-®Ц¤Я)</Txt> <!-- Turbo Ratio(2-Core) -->
<Txt Num="51">Turbo Ratio (3-®Ц¤Я)</Txt> <!-- Turbo Ratio(3-Core) -->
<Txt Num="52">Turbo Ratio (4-®Ц¤Я)</Txt> <!-- Turbo Ratio(4-Core) -->
<Txt Num="53">Turbo Ratio (5-®Ц¤Я)</Txt> <!-- Turbo Ratio(5-Core) -->
<Txt Num="54">Turbo Ratio (6-®Ц¤Я)</Txt> <!-- Turbo Ratio(6-Core) -->
<Txt Num="55">Turbo Ratio (7-®Ц¤Я)</Txt> <!-- Turbo Ratio(7-Core) -->
<Txt Num="56">Turbo Ratio (8-®Ц¤Я)</Txt> <!-- Turbo Ratio(8-Core) -->
<Txt Num="57">і]©wCPUЄєҐ\ЇУ·Ґ:banana::banana:(ҐЛЇS)</Txt> <!-- Turbo Power Limit(Watts) -->
<Txt Num="58">і]©wCPUЄє№q¬y·Ґ:banana::banana:(¦w°ц)</Txt> <!-- Core Current Limit(Amps) -->
<Txt Num="59">±Т°КCPU¦h®Ц¤Я§ЮіN</Txt> <!-- CPU Cores Enabled -->
<Txt Num="60">±Т°КCPU¦h°х¦жєь§ЮіN</Txt> <!-- CPU Multi-Threading -->
<Txt Num="61">CPU Enhanced Halt (C1E)</Txt> <!-- CPU Enhanced Halt (C1E) -->
<Txt Num="62">¤дґ©CPU¶i¤JC3/C6Є¬єA</Txt> <!-- C3/C6 State Support -->
<Txt Num="63">CPU·Е«ЧєК±±</Txt> <!-- CPU Thermal Monitor -->
<Txt Num="64">CPU EIST Ґ\Їа</Txt> <!-- CPU EIST Function -->
<Txt Num="65">Bi-Directional PROCHOT</Txt> <!-- Bi-Directional PROCHOT -->
<Txt Num="66">іq№DA ®Й§Зі]©w</Txt> <!-- Channel A Timing Settings -->
<Txt Num="67">іq№DB ®Й§Зі]©w</Txt> <!-- Channel B Timing Settings -->
<Txt Num="68">Extreme Memory Profile (X.M.P.)</Txt> <!-- Extreme Memory Profile (X.M.P.) -->
<Txt Num="69">DRAM®Й§ЗїпѕЬ</Txt> <!-- DRAM Timing Selectable -->
<Txt Num="70">Channel Interleaving</Txt> <!-- Channel Interleaving -->
<Txt Num="71">Rank Interleaving</Txt> <!-- Rank Interleaving -->
<Txt Num="72">ҐDѕчЄO№qАЈ±±Ёо</Txt> <!-- Mother Board Voltage Control -->
<Txt Num="73">Multi-Steps Load-Line</Txt> <!-- Multi-Steps Load-Line -->
<Txt Num="74">CPU Vcore</Txt> <!-- CPU Vcore -->
<Txt Num="75">Dynamic Vcore(DVID)</Txt> <!-- Dynamic Vcore(DVID) -->
<Txt Num="76">QPI/Vtt №qАЈ</Txt> <!-- QPI/Vtt Voltage -->
<Txt Num="77">ЁtІОAgent№qАЈ</Txt> <!-- System Agent Voltage -->
<Txt Num="78">CPU PLL</Txt> <!-- CPU PLL -->
<Txt Num="79">DRAM VRef.</Txt> <!-- DRAM VRef -->
<Txt Num="80">DRAM Termination</Txt> <!-- DRAM Termination -->
<Txt Num="81">Ch-A Data VRef.</Txt> <!-- Ch-A Data VRef -->
<Txt Num="82">Ch-B Data VRef.</Txt> <!-- Ch-B Data VRef -->
<Txt Num="83">Ch-A Address VRef.</Txt> <!-- Ch-A Address VRef -->
<Txt Num="84">Ch-B Address VRef.</Txt> <!-- Ch-B Address VRef -->
<Txt Num="85">Isochronous Support</Txt> <!-- Isochronous Support -->
<Txt Num="86">Virtualization Technology</Txt> <!-- Virtualization Technology -->
<Txt Num="87">ЁtІОјИ°±їп¶µі]©w</Txt> <!-- Halt On -->
<Txt Num="88">§Ціt¶}ѕч</Txt> <!-- Quick Boot -->
<Txt Num="89">CD/DVD ¶}ѕчїпѕЬ</Txt> <!-- CD/DVD Boot Option -->
<Txt Num="90">ІД¤@¶}ѕчёЛёm</Txt> <!-- First Boot Device -->
<Txt Num="91">ІД¤G¶}ѕчёЛёm</Txt> <!-- Second Boot Device -->
<Txt Num="92">ІД¤T¶}ѕчёЛёm</Txt> <!-- Third Boot Device -->
<Txt Num="93">µwєРS.M.A.R.T.Ґ\Їа</Txt> <!-- HDD S.M.A.R.T. Capability -->
<Txt Num="94">іМ¤jCPUID·Ґ:banana::banana::banana:И</Txt> <!-- Limit CPUID Max. to 3 -->
<Txt Num="95">No-Execute Memory Protect</Txt> <!-- No-Execute Memory Protect -->
<Txt Num="96">Delay For HDD (Secs)</Txt> <!-- Delay For HDD (Secs) -->
<Txt Num="97">ЕгҐЬ¶}ѕчµe:banana:±Ґ\Їа</Txt> <!-- Full Screen LOGO Show -->
<Txt Num="98">Init Display First</Txt> <!-- Init Display First -->
<Txt Num="99">Current System Temperature</Txt> <!-- Current System Temperature -->
<Txt Num="100">Current CPU Temperature</Txt> <!-- Current CPU Temperature -->
<Txt Num="101">Current CPU Fan Speed</Txt> <!-- Current CPU Fan Speed -->
<Txt Num="102">Current Power Fan Speed</Txt> <!-- Current Power Fan Speed -->
<Txt Num="103">Current System Fan1 Speed</Txt> <!-- Current System Fan1 Speed -->
<Txt Num="104">Current System Fan2 Speed</Txt> <!-- Current System Fan2 Speed -->
<Txt Num="105">Current System Fan3 Speed</Txt> <!-- Current System Fan3 Speed -->
<Txt Num="106">Current System Fan Speed</Txt> <!-- Current System Fan Speed -->
<Txt Num="107">CPU·Е«ЧДµ§i</Txt> <!-- CPU Warning Temperature -->
<Txt Num="108">CPU:banana:·®°¬G»ЩДµ§iҐ\Їа</Txt> <!-- CPU Fan Fail Warning -->
<Txt Num="109">ЁtІО:banana:·®°2¬G»ЩДµ§iҐ\Їа</Txt> <!-- System Fan2 fail Warning -->
<Txt Num="110">№q·Ѕ:banana:·®°¬G»ЩДµ§iҐ\Їа</Txt> <!-- Power Fan Fail Warning -->
<Txt Num="111">ЁtІО:banana:·®°1¬G»ЩДµ§iҐ\Їа</Txt> <!-- System Fan1 Fail Warning -->
<Txt Num="112">CPU Smart Fan Control</Txt> <!-- CPU Smart Fan Control -->
<Txt Num="113">Slope PWM</Txt> <!-- Slope PWM -->
<Txt Num="114">CPU Smart Fan Mode</Txt> <!-- CPU Smart Fan Mode -->
<Txt Num="115">USB±±Ёоѕ№</Txt> <!-- USB Controllers -->
<Txt Num="116">USB Legacy Ґ\Їа</Txt> <!-- USB Legacy Function -->
<Txt Num="117">USBАx¦sёЛёmҐ\Їа</Txt> <!-- USB Storage Function -->
<Txt Num="118">OROM UI and Banner</Txt> <!-- OROM UI and Banner -->
<Txt Num="119">R_USB30 ±±Ёоѕ№</Txt> <!-- R_USB30 Controller -->
<Txt Num="120">R_USB30 Turbo</Txt> <!-- R_USB30 Turbo -->
<Txt Num="121">F_USB30 ±±Ёоѕ№</Txt> <!-- F_USB30 Controller -->
<Txt Num="122">¤є«ШєфёфҐ\Їа</Txt> <!-- Onboard H/W LAN -->
<Txt Num="123">¤є«ШєфёфBoot ROM</Txt> <!-- Onboard LAN Boot ROM -->
<Txt Num="124">eXtreme Hard Drive (XHD)</Txt> <!-- eXtreme Hard Drive (XHD) -->
<Txt Num="125">PCH SATA ±±Ёоѕ№јТ¦Ў</Txt> <!-- PCH SATA Control Mode -->
<Txt Num="126">SATA Port0-3 Native јТ¦Ў</Txt> <!-- SATA Port0-3 Native Mode -->
<Txt Num="127">GSATA3 ±±Ёоѕ№</Txt> <!-- GSATA3 Controller -->
<Txt Num="128">GSATA3 CtrlјТ¦Ў</Txt> <!-- GSATA3 Ctrl Mode -->
<Txt Num="129">eSATA3 ±±Ёоѕ№</Txt> <!-- eSATA Controller -->
<Txt Num="130">eSATA3 CtrlјТ¦Ў</Txt> <!-- eSATA Ctrl Mode -->
<Txt Num="131">¤є«Ш:banana:µ®ДҐ\Їа</Txt> <!-- Azalia Codec -->
<Txt Num="132">Onboard H/W 1394</Txt> <!-- Onboard H/W 1394 -->
<Txt Num="133">¤є«Ш§З¦C°р1</Txt> <!-- Onboard Serial Port 1 -->
<Txt Num="134">ACPI ¬Щ№qјТ¦Ў </Txt> <!-- ACPI Suspend Type -->
<Txt Num="135">№q·Ѕ¶}ГцЄєГцѕч¤и¦Ўі]©w</Txt> <!-- Soft-Off by PWR-BTTN -->
<Txt Num="136">PME ЁЖҐуікїфҐ\Їа</Txt> <!-- PME Event Wake Up -->
<Txt Num="137">Power On by Ring</Txt> <!-- Power On by Ring -->
<Txt Num="138">HPET Ґ\Їа¤дґ©</Txt> <!-- HPET Support -->
<Txt Num="139">HPET јТ¦Ў</Txt> <!-- HPET Mode -->
<Txt Num="140">·Ж№«¶}ѕчҐ\Їа</Txt> <!-- Power On By Mouse -->
<Txt Num="141">БдЅL¶}ѕчҐ\Їа</Txt> <!-- Power On By Keyboard -->
<Txt Num="142">В_№q«б№q·Ѕ¦^ґ_®ЙЄєЁtІОЄ¬єAїпѕЬ</Txt> <!-- AC Back Function -->
<Txt Num="143">ErP Ґ\Їа¤дґ©</Txt> <!-- ErP Support -->
<Txt Num="144">ЅT»{</Txt> <!-- Confirm -->
<Txt Num="145">Аx¦s CMOS</Txt> <!-- Save CMOS -->
<Txt Num="146">¶}±Т</Txt> <!-- Enabled -->
<Txt Num="147">Гці¬</Txt> <!-- Disabled -->
<Txt Num="148">¦Ы°К</Txt> <!-- Auto -->
<Txt Num="149">µwєР</Txt> <!-- Hard Disk -->
</Text>
stasio why is posted here if it dont work for us on P67 ? u tried it ?
thanks
Sergio
just get this babies :D
booted as a charm on specs
2x4GB modules 2133 9-10-11-28 1T 1,65vdimm
http://img683.imageshack.us/img683/1951/p1090354r.jpg
http://img405.imageshack.us/img405/5...1339111028.jpg
http://img571.imageshack.us/img571/7...11028hyper.jpg
cheers !
Sergio
Cleaned up my dusty old 295 stock air:D
http://img593.imageshack.us/img593/3...nshot007mh.jpg
GA-P67A-UD7-B3 - F4
-fix bug with DVID (LLC disabled)
-02.May 11
so anyone try their luck with new bios yet:rofl:
i'll wait odds are like 90% of the bioses its gonna create boot loops:ROTF:
