Don't be too put-off because of the BIOS', even though it's a mixed bag, the next release will surely make things a hell of a lot better ;)
Speaking of next release, where is it? Is there an ETA?
Ahh, didn't look well in the signature, thought it only an image. No need for CPU tab, OCCT displays everything needed, and PC Probe the vcore. Nice WC, very close to mine except an Apogee GT and a PA120.3 instead of the Fusion and MCR-320. I'll also invest in a MCW30 for my new MB.
Give OCCT last beta a try (Link), and put the slider in RAM 1024Mb mode. Hope you keep stable :confused: it really stresses the NB-RAM at maximum. If it fails, your F@H also could fail, and suerely from time to time a game or other stuff...
Please let me know once done, you have just the best yet stable OC on this board
alright guys.. im having some problem with my computer booting.
E6850 / Maximus / Tracers 8500 / Zeus 750
Cooled by W/C in my sig
after i power on, it doesnt say anything.. on the lcd it just says cpu init
are you with default settings?
New OCCT hard locks and then reboots my system...
i havent even got my computer into the bios.
Just hooked up everything last night and havent even gotten it to post yet..
help please!
i tried for 18 minutes and it was stable... couldn't get OCCT to stop the test though lol. i had to use task manager. anyway, i'll try running it longer later on. i don't think i'll have a problem though as i'm using a 1:1 divider and the ram isn't overclocked much.
try one stick of ram and let me know how that goes... try the 800 stick you have.
That's it. I'm trying to convince that Prime95 Blend is far from being a good stability test for the NB-RAM subsystem... You just saw it, sorry for you
Look at my signature. OCCT RAM will reboot me at 391MHz, I'm stable at 390MHz FSB. If my I set my vDDR to 2.0v, same thing. Of course, Prime95 small/large/blend is always happy on all settings
Hope more people will use OCCT RAM so we can have real stability measures instead of promising stable systems while they bug in games and randomly
Here you go, top 3 are the Extreme Tweaker page, bottom 2 just to see if they are set ok?
http://img251.imageshack.us/img251/9...0fsb-00.th.jpg
http://img251.imageshack.us/img251/4...0fsb-01.th.jpg
http://img251.imageshack.us/img251/6...0fsb-02.th.jpg
http://img251.imageshack.us/img251/5...0fsb-03.th.jpg
http://img251.imageshack.us/img251/7...0fsb-04.th.jpg
Thanks... :yepp:
Great, good news, you are stable for 18mn which is already very good. If OCCT in RAM mode is stable for 1-2h, then it is probably stable for real.
For the priority issue, you have to set priority in "configuration panel" to lowest, it is a bug in the beta. Once on lowest, you could use your computer normally
I am trying this OCCT utility but the slider won't move because it's drawn at the top of the utility and when I click it to change RAM test size, it moves the application around screen instead. Anyone else have this problem or how to fix it, I looked in the OCCT.ini but did not see an option to define memory test size.
You can drop South Bridge back to stock voltages.. increasing it makes absolutely no differences.
Enable Loadline Calibration as this helps with vDroop.
Set DDR2 REF Voltage to nominal (the middle setting).
Disable both Spread Spectrums because they cause instability at high frequencies.
You're not overclocking your CPU? the voltage is set unnecassarily high.
The slider is active for custom test selection in the drop menu. So select, custom test in drop menu, then select the slider
Final version should be more beautiful/agenced
Official OCCT forum, final version coming soon:
http://forum.hardware.fr/hfr/Overclo...t_227556_1.htm
edit:
Please note, I'm not implicated in OCCT developement (except I followed the beta testing when I discovered, like you, that OCCT in ram mode will put much more stress on the NB and RAM than Prime95). If OCCT RAM fails, even F@H will fail from time to time on >12h run while OCCT RAM will fail in 1 to 2h. The new chips with a quad core are difficult to overclock because of an FSB-NB-RAM issue. Only OCCT in RAM mode unveals it, and F@H (but needs longer runs). I'd like to buy an X38 board and get +3.8GHz, but it has to be OCCT stable too in addition to Prime95.
Anyway, the Samurai got a great stable overclock it seems, and OCCT RAM stable, so this board should do it with the good settings/memory
Sorry, should have pointed out I am trying to overclock my cpu higher, its an E6550 2.33ghz FSB1333 and it is currently at 400x7 = 2.8ghz.
The problem is, everytime I try to push the fsb higher the system won't boot and I think its down to the memory but i'm not sure where i'm going wrong.
I have seen on other forums at least 3.2ghz and a review made it up to 3.85ghz with the E6550 using different motherboards!
Thanks, that got it working. I should have tried that.
What's the max voltage your RAM can take according to spec? make sure you're not undervolting or overvolting your RAM.
Mem timings apart from the ones you set can be left on Auto.
if 4-4-4-12 doesn't post, try 5-5-5-15 and then Memtest, if that post's ok try 5-5-5-12.
You might be better off enabling Transaction Booster and setting it to 0, also set Ai ClockTwister to Strong.
If you find that this works, try putting Transaction Booster on 1 afterwards.
Some people say that Transaction Booster doesn't work properly, but it works fine for me and increased my mem read speeds a little.
If increasing the latency helps you to post, you can probably try to drop the North Bridge volts a little, but that's only worth doing if you are worried about temps! if your NB is staying below 58-60c then you should be fine.
Refer to my post earlier regarding my listed BIOS settings if you are puzzled with setting up voltages.
2.0V is the max according to spec, so I set it to 1.9V to cover the overvolting...
4-4-4-12 is what my mem is supposed to be set at for 800mhz, its the Low Latency stuff...
I'll give all your help a try later and report back, for now you have been very helpful. Its much appreciated!! :clap:
