fuj primoz78 :D
fuj primoz78 :D
Has anybody here got a opteron 146 from alternate the recent days? I orderded one yesterday and I'm wondering which stepping it has. I will post results when he arrives.
richdog: how much did you payed, do they have good steppings ? any url of site please ;)
Tomorow i 'll have an 146 CABYE 0540 FPBW.
someone got result ?
Hi all!
I just thaught I could help some people looking for s939 Opterons. There's a german store, http://www.overclockers.de, that has quite a few opterons in stock. The steppings of the 146:s and 148:s, in stock are:
148 boxed
cabye 0536 gpmw
148 tray
cabye 0535 xpmw
146 boxed
cabye 0540 fpbw
146 tray
cabge 0536 vpmw
I really hope this help someone.... :toast:
from where????Quote:
Originally Posted by Pt1t
Currently using the DFI nF4 Ultra-D, but I've got the Sapphire Pure Innovation Ati coming on friday.Quote:
Originally Posted by hesky
Nick
oden: you sure about overclockers.de
146 boxed
cabye 0540 fpbw
187€ ?
HAA i did broke 3ghz wall with CABGE and outsideair about +4c and zalman 7700cu and 1.7xxx vcore :) and sp8m @3010@5min 00s
sp1m@3041@ 26s
its trule very good cabge :fact:
tomorrow i will post my results :toast:
poorer oc'ing 146 CABYE 0540FPBW on Corsair Hydrocool 200EX
http://www.fileshosts.com/watercooli...rocool_001.jpg http://www.fileshosts.com/watercooli...rocool_003.jpg http://www.fileshosts.com/watercooli...rocool_005.jpg http://www.fileshosts.com/watercooli...rocool_006.jpg
SS
http://www.fileshosts.com/DFI/NF4_SL...S/cpu-3201.jpg
1M
http://www.fileshosts.com/DFI/NF4_SL...erpi-1m_tn.jpg
cpuz validated url:
http://valid.x86-secret.com/show_oc.php?id=47429
Not looking great for the CAB2E at initial glance... booted at 2.8ghz at 1.45v and got a reboot. Upped it to 1.5v and Super PI 1MB fails instantly.
I'll increase the voltage and see where I get stable at...
EDIT - Think my PSU can't cut it. :(
Don't recall if you mentioned it earlier, but how high are yours booting at default voltage?Quote:
Originally Posted by eva2000
read http://i4memory.com/showthread.php?t=1594Quote:
nearly all 146 CABYE 0540FPBW are hitting 3ghz at either low 1.42v vcore or 1.536-1.584v vcore
low vcore 3ghz ones don't seem to scale well with vcore past 3ghz, while the higher vcore 3ghz ones seem to scale a bit better
but all depends on cooling too!
both my 146 CABYE 0540FPBW are the 3ghz at 1.536v and 1.552v kind of cpus
read http://i4memory.com/showthread.php?t=1594 :DQuote:
Originally Posted by nightic
depending on psu AUTO vcore = 1.36v or 1.376v so really hard to say but 1st 146 auto vcore only 2800mhz 2nd 146 auto vcore 2900mhz
What kind of temps you getting?Quote:
Originally Posted by Richdog
34c according to MBM... but to be taken with a liberal pinch of salt I expect.
i would agree. my 146 that hits 2.9ghz with 1.425v needs ~1.55v to almost stabilize at 3ghzQuote:
A shop here in Hong kong has 2 Opterons.
1. 144 CABNE
2. 146 CABYE
I don't know their manufactured date, but is it worth getting over my 4400+ X2?
Or should I just want for the dual core opteron?
Wait for M2 ;)Quote:
Originally Posted by typer77
Otherwise go for 144, in the worst case you get a few more things to play with.
My problems seem to be rooted to the fact that *something* in my system isn't a big fan of the 9x multiplier: 8x275 2.5-3-3 1T is fine, 9x275 BSODs, but 8x320 (166 divider) is fine...gah. Being limited to 8x is going to limit my overclock majorly. Suggestions?
Kameleon what clocks are you getting at what voltages?
Try a different bios.
Have you tried using a high HTT with a 9x multi but a really low (or high depending on how you look at it) divider on the memory, so it's running down in the 200 Mhz region?Quote:
Originally Posted by Kameleon
Good point, all you guys struggling should be using a tall memory divider, at least 150 or even 133 to completely rule out the memory for now. Also, don't forget to lower the HTT multi to 3 too. I don't like anything auto, I don't trust it. :nono:Quote:
Originally Posted by Jimbo Mahoney
Not thoroughly (had a brief go with 133 divider inamongst everything else), I'll have to give it a go. If that has no effect I'll move from the 1.3b6 1T BIOS to the 1.8 1T BIOS (I was on trats 1.37 before and that gave me the same problems). LDT has been on 3x throughout, I'm a bit wary of dropping it to 2.5x or 2x, is either one more advisable than the other?Quote:
EDIT:I've not gone above 2700, on stock volts - the board has been holding me back way before that, and much over 300HTT and it also dies at the moment. Can't really find out how the CPU does until I solve the other problems, but let's just say that it's not my bottleneck. I wish I'd got one of the 146s now, despite the supposedly better memory controller on the CAB2E, it's not doing me much good. I'd rather have 10x. Might be having to go PCI-E and get a new board...Quote:
