DUDE... That is a sick rig. :eek: Very good work. :up: Only thing that might need work are the cables, but it is very nice.
looks good, hate the stickers tho
@Tommy_Hewitt
What casing are you using , I would assume that the TRUE 120 will fit on that case as it doesnt fit currently on my Coolermaster Praetorian 72x
@Tommy_Hewitt, what kind of camera? It seems more crispier shots.:up:
Play around with the macro + timer (less shaking or blurring) to get right detail & lighting conditions.
Or try using one of these Gorillapod,
http://img138.imageshack.us/img138/5...milyiy8.th.jpg
works wonders :up:
I see, well my current PSU ( Silverstone Zeus 750ZF ) doesnt have a bottom fan, it uses a front fan so i guess there wont be any issues if i decide to get this case.. is the case width enough ? the entire HS is about 160mm tall my CM casing is about 180-190 in width but has about 20-25mm open distance on the back for wire storage, i think i have a total of 155mm clearance from the mobo stand offs to the side panel.
I can tell you, that it's width enough. The TRUE 120 fit in this case very good, but the socket of my DFI board is too near to the PSU, so i cant use this cooler
The Asus P5B Deluxe depresses me in so many ways. =[
Not my normal set-up (check the WC gallery :D)
But had my PC like this to test the DFI:
http://i49.photobucket.com/albums/f266/Mankz_91/2-9.jpg
Has a Stock AMD X2 HSF on my 146 tho.
^ is that the mobo tray of a Coolermaster ATC 201?
Its from a Wavemaster, so Yes.
I found it for sale at a Comp shop for a fiver, so I snapped it up! Its brilliant for bench-testing I find.
I've currently got my pc on one of those trays (i have the atc 102 aswell) untill my Lian-li A71 comes :D
Nice choice of case :D
thanks :D ill be leaving the world of air cooling soon :o
Good Move Too. I love my water... :)
Not very big, I think you wouldn't be albe to get a Thermalright 120 in there..
Problem is the 80mm at the back.
^^ true. IIRC there is ~3cm differene between the height of the TRUE and the side pannel
Some pics of my brother's HD2900Pro :)
http://www.abload.de/img/1024x768cdp.jpg
http://www.abload.de/img/1024x7682bmj.jpg
http://www.abload.de/img/2xhde67.jpg
Nice pics!
Nice pics tommy :)
You have to tell me what settings you´ve used for the pictures.
Now two new pictures of mine.
http://www.abload.de/img/dscf0098kh8.jpg
http://www.abload.de/img/dscf0096ljl.jpg
Steffen did the Ultra 120 Extreme not fit in the other direction, and if it didnt, by how much?
steffen, great job with the wiring, would you mind showing me how you did it? I have the same case but I'm not too sure if I need to drill anything out or not to hide the wiring.
Very nice Steffen
Great cable management
