Oh, THAT Trick....
Forgot that didn't work for DOM, but DOM's *backup* BIOS got corrupted...not his main...
will try this one first ...thanks a lot for all the inputs and help !
GIGABYTE Touch BIOS
http://www.youtube.com/watch?v=2ozr7...layer_embedded
Edit:
http://www.techpowerup.com/144776/Gi...p-Program.htmlQuote:
It turns out that TouchBIOS isn't a firmware application, but rather a Windows-based utility
tried the keyboard thing and shorting pin 6-7 same result ...is this a dead board already? any other trick that i can try? sorry for disturbing you people but i really need help :)
Has anyone tried the F8x bios....... anyone?
Had the same issue with my UD7 and I ended up RMA'ing it. Not sure about the shorting trick but it happened to me while flashing a backup bios. It seemed to complete the bios backup but then shut down at the end of the flash. Once that happened it would continually reboot and nothing seemed to helped.
Well after this site loaded those pages :cool: I see that it may take a bit more voltage vs f7e/f but eva seems to like it. I guess I will stick with it.
Thanks for pointing me to the right page.
EDIT: Has anyone gotten CLoud OC to work on this board? I can change all the voltages, but only the memory multiplier up top. I uninstalled the latest version (on giga's website) of ET6 and then I suddenly got cpu multi changes. No bclk, no pcie, or anything else...Any thoughts on this?
the liar chose 0.9v for vdimm ...lol
..you need a touchscreen? bs
Does anyone see a problem with running F8x as the primary and F3 as the backup outside of F3's talked about shrotcomings? SHould I go f8x/f8x?
Im loving this board for 3D. Did some more benching today. Got carried away with the vcore in the first screen, LLC2 adds a ton of vcore.
Thanks Dumo for all the help :up:
Nice runs OC:up:
Found vista in my office:D
'05 still look so pretty:)
Next will try with ATI Trays
http://img683.imageshack.us/img683/1...nshot002cm.jpg
F8x was for me the best bios of the B2 revision board ... you can keep it.
About your second question, this bios is less easy to corrupt, i have never get the need to use the backup bios ( something who was happend a lot with early bios ) ... free to you to see if you want keep the old bios in backup or not.
Back to flashing! :)
One more Q if I may...
Giga's Cloud OC. Has anyone tried it? I can only seem to change the CPU multi and memory multi with it. Can anyone else change bclk, pcie, etc with the Cloud OC tool? Either via web or Droid?
Z68X BIOS is updated on TT forum. :D
http://i4.aijaa.com/b/00644/7963398.bmp
Hey guys
I know aint the right section to post but i need your help
im looking to buy 1 stick of Mushkin Redlines Ridgeback Red HS 1600 6-8-6-24 1,65v in order to complete my 3x2kit to 4x2
the model is 998970
http://img27.imageshack.us/img27/9051/memq.jpg
Uploaded with ImageShack.us
if anyone has one please PM me
thanks to all
Sergio
you might want 1 of these:D
http://www.newegg.com/Product/Produc...82E16820226203
run 12gb:D
unless you get lucky
