u can use different monitors with different resolutions.
however, for eyefinity you need the same set res, as 1920x1080x3.
but for office work, without eyefinity, 3 screens works different resolution to my knowledge.
did the new drivers help cross fire results???
Guys anyone has tried the newer drivers from amd website dated 10/13/2009? Did anyone of you notest any difference? its only for series 5000 graphics
You will only loose the upper and maybe the middle hard drive bays with a little modding. But if you got the cash for an 5870x2 then you can get an ssd and put it somewhere else.
has voltage control and much higher over clocking setting in ccc and afterburner.
3K of GPU score? How did ya? Perhaps i'm limited my CPU, don't know.
My GPU score difference is:
before with 1st release recomended AMD drivers:
GPU SCORE = 15918
Now Lastest recomended drivers dated 10/13/2009
GPU SCORE = 16028.
My system is:
Asus M4A79 Deluxe
AMD PHENOM II 940 @ 3.6
GSkill TT @ 1066
XFX 5870 @ completely stock
My results are almost exactly the same....~16,000 (3D Vantage-performance settings)....same score from several reviewers (w/ i7) of the 5870, so I think this score is normal, and not cpu limited for a gpu @ stock. And the so called new driver did not jump Vantage by 3K, as indicated above.
Thanks mate, i was thinking to me that 3k was to big to be true, but thanks for your confirmation!
My score also jumped by 3k atleast. For some reason i was only getting GPU score of 12000 but the new drivers sorted that out. :up:
Can anyone VERIFY this?
5770 voltmod
According to this:http://www.st.com/stonline/products/...341/l6788a.pdf
and http://img131.imageshack.us/img131/6659/vregsmall.jpg
and assuming that pins count from the arrow right?
This is only if someone,after support for this chip exists,still needs more than 1,35 volts,this chip can output!
The pin on the yellow circle would be the FB pin,the one to solder a resistor or to find a connected resistor with RIGHT guys?Not absolutely sure!Anyone brave enough to try this out?
EDIT:After reading more carefully the pins description,i got confused with the the pins 19-and 20.Anyone can help???
Is there somebody know how to unlock the limit clock of 5770 ??
This is msi 5770 Bios.
MSI 5770(Juniper).bin
Is there anyone can help me unlock it?
Thank you very much.
Can some please post or PM me the BIOS for a Sapphire 5870, I need some backup ones, GPU-z wouldnt let me save them before I flashed my card to the Asus BIOS, give me a hand, please :)
Where on earth do I find a decent trifire driver for these cards ? seems 8.14.10.700 is the only sort of decent version working, yet I can't find it anywhere ...
Go to http://www.techpowerup.com/vgabios/5...24.090914.html
that's my BIOS :)
If anyone wants so read my test of HD 5850 and HD 5870 (CF combination, games, 3dmark,...) you can find it here: http://www.oc-lab.si/test.php?t=110
It is in Slovenian language, but pictures and numbers are universal anyway:D
Best regards M-XXXX
