Hi to all, i have understand like extract and substitute the module raid for sata v8 and the Lo72 raid and memory table with mmtools and the bios works well,,
but the question is: for cpuid what is the modules? thanks..
Ehi guys, only the last, the cpuid in that way can i change?
Thanks, the rest works..
up
The cpuid in which way can be changed? Thanks
OKAY, I'll upload the new version of it tonight.
chenxuwen hi, i have understand how mod my bios for asus p5q deluxe,, i insert slic asus, memory table from rampage extreme, L73 (i don't use raid 0), intel raid for sata 9.6 (i don't use lan boot rom), image oem change, etc.. and the bios works amazing, prime 95 9 hours + super pi for 4 cores with trivial kingston stable to 858MHz 5-5-5-15 only with this memory table...
The problem is: i have also a p5q, in which way i can the cpuid for this mobo with that of p5q premium or also my deluxe? This, which is the module to change with mmtool?
Sorry for my english
up
for cpuid?
up for change cpuid please, only this ...
Bump because everybody seems to love this thread still.. but seriously guys, your flogging a dead horse now everything that can be done for the P5Q series HAS been done.
Title says it all. This post is just to show the basics of what you can do with MMTOOL so you can at least do a few things yourself and don't have to wait for one of the modders.
First up, a image of what all the module IDs are:
http://img.photobucket.com/albums/v1.../ModuleIDs.png
Second, a SS of MMTOOL:
http://img.photobucket.com/albums/v1...lipboard02.jpg
Now, for some details about MMTOOL 3.22, its the latest version available (AFAIK) and this modified version of MMTOOL allows people to successfully work with the 1B module and the 21 module without borking the BIOS. Using MMTOOL is very simple, literally just browse the location of the file you want to open, then extract / replace modules as needed.
Does anyone have a download link for P5Q-E 1703m BIOS? I lost it in a drive format and I had good success with overclocking while using it.
Thanks.
Edit: Found them in the first download link.
Can any of the active modders be so helpful and prepare the newest BIOS for P5Q-E with newest Intel RAID ROM, JMB368 ROM and memory table? Also ASUS SLIC 2.1 would be nice.
I don't have any experience with modding BIOS files and I don't want to screw something up and make my motherboard unusable.
I've seen that there are many BIOSes with those futures, but non of them is for P5Q-E.
If anyone would build one, I would be very grateful.
Ok, thanks for answer. But this stuff is "stuff" that already i know.
My question, my one question, was: what is the module from replace about cpuid?
The module 11, or the 0C. I have replace both on my p5q with module of maximus formula and the bios works great.
But i have this doubt, still
Only this, thanks;)
Hello
I've got a P5Q Deluxe with Q9650 & 4x2GB
I would like to insert memory table from Maximus II Formula to my bios in order to overclock.
Someone could explain to me how to do it?
Thank you very much in advance
Regards
edited
I'm running the P5Q with a Q9550 @ 3.62 and 4X2Gb @ 1066. Standard bios!!
Memory is a corsair quad set 6400C4 which runs fine at 1066C5 too.
why on earth would you integrate a DDR3 ram set to a DDR2 ram set, P5Q Dlx overclocks DDR2 ram beyond 1100mhz easily... no idea why you would want to mess with the bios...
Sorry I've made a mistake, I was talking about Maximus II Formula ^_^
No because the MF II is a POS, your Mobo actually has better OC.
All right thank you.
Finally with 2201
http://img10.hostingpics.net/pics/98858Capture.png
Stable under LinX & OCCT
@ scharnhorst, the M2F has a good memory table, on par with the P5Q Deluxe and most notably has a bit better latency over the Deluxe. Before splicing memory tables about research various boards, the memory table you will ideally want to use is the one with your memory listed in the QVL.
i will try for P5Q-E in term of overclocking/vcore/fsb
Thank you very much Ket.
My rams are :
Corsair XMS2 DHX C4
gSkill Pi Black
I found the corsair in the QVL but not the gskill. I will look for the other motherboard
Thank you for yout help
Its P45 so still counts :p: I have somewhat of a super BIOS for the Maximus 2 Formula I need people to help me test as I don't have all the hardware to test all the improvements. Who wants to help?
On a more relevent, useful note. What were the last BIOSes you P5Q / Pro / -E / Deluxe owners tried? I have a few more tricks up my sleeve I guess I could do as chen hasn't popped in in a while.
