Hi TiesumQuote:
Sure!
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
Ratio CMOS Setting : 9
FSB Frequency : 470
PCI-E Frequency: 100
DRAM Frequency: DDR2-1129
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency :5
RAS# to CAS# Delay :5
RAS# Precharge :5
RAS# ActivateTime :15
RAS# to RAS# Delay :AUTO
Row Refresh Cycle Time :AUTO
Write Recovery Time :AUTO
Read to Precharge Time :AUTO
Read to Write Delay (S/D) :AUTO
Write to Read Delay (S) :AUTO
Write to Read Delay (D) :AUTO
Read to Read Delay (S) :AUTO
Read to Read Delay (D) :AUTO
Write to Write Delay (S) :AUTO
Write to Write Delay (D) :AUTO
Ai Clock Twister : Auto
Transaction Booster : Disabled
Relax Lvl: 1
CPU Voltage : 1.45625
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.49
DRAM Voltage : 2.14
FSB Termination Voltage : 1.44
South Bridge Voltage : 1.05
CPU GTL Reference : 0.63
North Bridge GTL Reference : 0.67
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : 1.50
NB LED Selection : FSBT Volt
SB LED Selection : SB 1.5 Volt
CPU LED Selection : PLL VOlt
Voltiminder LED : Enabled
Advanced CPU Configuration
Ratio CMOS Setting : 9.0
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
Good luck! Please let us know if this gives you a stable OC.
Did you try to play game with this setting and no error ?? Because I got "Nvidia Driver stopped responding" message when gaming with this setting
